How to ncopy multiple at same place or pause the ncopy command?
darkfprh
darkfprh
Hi I want to copy some entities from xref and paste same place.
(command "ncopy" pause pause "0,0" "0,0")
So I tired to pause the command until selection in over.
But select multiple entities, it doesn't work... Please help me
ВeekeeCZ
Not so easy to do. Possibly like this
(while (setq e (cadr (nentsel))) (command "ncopy" e "" "" ""))
But is it really necessary? I mean, how difficult is it to hit enter a couple of times.
Anyway, just a few threads lower @pbejse posted a nice example of code how this could be done without the need to fight with ncopy. HERE
(vl-load-com)
(defun c:demo (/ obj tmp)
  (while (setq obj	(nentselp "\nSelect object to copy "
		) ;_ end of nentselp
    (progn
      (setq tmp (entmakex (entget (car obj))))
      (vla-transformby
	(vlax-ename->vla-object tmp)
	(vlax-tmatrix (caddr obj))
      (Vla-put-layer (vlax-ename->vla-object (entlast)) (getvar 'clayer))
darkfprh
Thank you so much! It works well 🙂
cadomatic
very nice!
is there a way to select all objects in the selected object layer and transform them in one click?
ancrayzy
Thank you so much.
