How to make a slide of a given size?
iBlachu
iBlachu
How to make a slide so that from edge to edge of the slide there is only the object itself?
I know you can scale the window for the duration of the slide, but is there another way?
paullimapa
try by going to pspace and creating a vport that is sized accordingly
then go inside that vort and start VSLIDE command
Paul Li
IT Specialist
@The Office
Sea-Haven
Slides started in the year dot of Acad, when a good screen was color and 640x480, I shrink my Acad/Bricscad screen down to a bit less than a 1/4 screen, I try to only have the objects present I want in the slide then zoom e then zoom 0.9xp and make slides. With 4k monitors now making slides it is a bit hit and miss.
You can batch make slides using a script etc.
