How to lock all table cells in a drawing
Message 1 of 30
I'm looking for a command to incorporate into my routine that will lock all the cells in various tables at the end of my routine. Does anybody know how to do this? Thanks!
Replies (29)
Message 2 of 30
pbejse
Only I have the key 🙂
Message 3 of 30
So do you know or not?
Message 4 of 30
ronjonp
Try this  .. feed it your vla-table:
(defun _allcellsto (tbl state / c r)
  ;; RJP » 2020-10-14
  ;; accellstatenone (0)
  ;; accellstatecontentlocked (1)
  ;; accellstatecontentreadonly (2)
  ;; accellstateformatlocked (4)
  ;; accellstateformatreadonly (8)
  ;; accellstatelinked (16)
  ;; accellstatecontentmodified (32)
  ;; accellstateformatmodified (64)
  (repeat (setq r (vla-get-rows tbl))
    (setq r (1- r))
    (setq c (vla-get-columns tbl))
    (repeat c (setq c (1- c)) (vl-catch-all-apply 'vla-setcellstate (list tbl r c state)))
  (princ)
;; Usage to lock all cells
;; (_allcellsto (vlax-ename->vla-object (car (entsel))) 1)
Message 5 of 30
pbejse
Since you ask nicely, No I Do Not Know, suffering from ID 10 T syndrome.
FWIW, if you are wanting to lock ALL cells might as well lock the table itself.  uhhm layer .. lock.. maybe
EDIT: No need for the act now @ronjonp  posted the code before i had the chance 😄
Message 6 of 30
pbejse
You spoiler you 😁
Party pooper.
Message 7 of 30
ronjonp
@pbejse wrote:
You spoiler you 😁
Party pooper.
Message 8 of 30
Hey! thanks for the response!
This is what I'm currently using to unlock all the table cells in my drawing-- I figured it would be a quick easy fix to use the same script to lock all my cells but I'm having some difficulty.
(defun AH:lockcell ( / x y)
(setvar 'ctab "Model")
(setq y 0)
(setq ss (ssget "X" (list (cons 0 "ACAD_TABLE"))))
(repeat (setq X (sslength ss))
(setq obj (vlax-ename->vla-object(ssname ss (setq x (- x 1)))))
(setq nRows (- (vla-get-rows obj) 1))
(setq nCols (- (vla-get-Columns obj) 1))
(setq row 0)
(setq cell 0)
(vla-put-RegenerateTableSuppressed obj :vlax-true)
(while (<= row nRows)
(while (<= cell nCols)
(vla-setcellstate obj row Cell 0)
(setq cell (1+ cell))
(princ (strcat "\nRow : " (itoa row) " , cell " (itoa cell)))
);while
(setq row (1+ row))
(setq cell 0)
(vla-put-RegenerateTableSuppressed obj :vlax-false)
)(princ)
(AH:unlockcell)
I have tried changing this value to a 1, 2, and 4 but it doesn't seem to work. Any ideas? I feel like it should be as simple as changing a single argument in a single command.
Pls help this will literally perfect my script
Message 9 of 30
ronjonp
OK .. spoon and all 😀
(defun c:foo (/ _allcellsto o s)
    ;; RJP » 2020-10-14
      (setq r (1- r))
    (princ)
  ;; Usage to lock all cells in all tables
  (if (setq s (ssget "_X" '((0 . "ACAD_TABLE"))))
    (foreach tbl (mapcar 'cadr (ssnamex s))
      (if (vlax-write-enabled-p (setq o (vlax-ename->vla-object tbl)))
	(_allcellsto o 0)
  (princ)
Message 10 of 30
cadffm
Try it like lazy stupid people like me
Set one cell lock like you  want (format,content or both),
then check the property..
Reverse engineering 😉
Sebastian
Message 11 of 30
That doesnt run at all for me 😞
Message 12 of 30
ronjonp
Did you check your tables? The code above does not return anything. Works on my test drawing 🤔
Message 13 of 30
My tables are currently unlocked and I ran that routine and nothing happened. But yes it returns nothing, but the goal isnt being accomplished 😕
Message 14 of 30
ronjonp
Post your sample drawing.
Message 15 of 30
Message 16 of 30
ronjonp
You need to post your drawing .. can't troubleshoot a screen capture.
Message 17 of 30
here ya go, had to strip it down to avoid giving away any company info 🤐
Message 18 of 30
ronjonp
Not sure what's happening for you. They all appear to lock when I run the code (FOO) .. take a looksee.
Message 19 of 30
hak_vz
(defun c:LockAllTables nil (LockAllTables))
(defun c:UnlockAllTables nil (UnlockAllTables))
(defun LockAllTables ( / ss i j k nrows ncols to)
	(cond
		((setq ss (ssget "_X" '((0 . "ACAD_TABLE"))))
			(setq i 0)
			(while (< i (sslength ss))
				(setq to (vlax-ename->vla-object (ssname ss i)))
					(setq nrows (vlax-get to 'Rows) ncols (vlax-get to 'Columns) j 0)
					(while (< j nrows)
						(if (= (vlax-invoke-method to 'GetRowType j) acTitleRow) (vla-SetCellState to j 0 accellstatecontentlocked ))
							(progn
									(setq k 0)
									(while (< k ncols)(vla-SetCellState to j k accellstatecontentlocked)(setq k (+ k 1)))
					(setq j (+ j 1))
			(setq i (+ i 1))
(princ "\nAll tables are locked!")
(princ)
(defun UnlockAllTables ( / ss i j k nrows ncols to)
	(cond
			(setq i 0)
					(while (< j nrows)
						(if (= (vlax-invoke-method to 'GetRowType j) acTitleRow) (vla-SetCellState to j 0 0 ))
							(progn
									(setq k 0)
									(while (< k ncols)(vla-SetCellState to j k 0)(setq k (+ k 1)))
					(setq j (+ j 1))
			(setq i (+ i 1))
(princ "\nAll tables are unlocked!")
(princ)
If it works then accept is as solution!
Miljenko Hatlak
Message 20 of 30
It is not doing anything for me when I type foo in and hit enter
Literally nothing. I run an unlock routine first, and then the lock code you provided. I wonder if the unlock routine is overpowering the lock routine since it is automatic in my drawing?
