Visual LISP, AutoLISP and General Customization
how to list all of loaded lisps in Autocad?
17 REPLIES 17
Message 1 of 18
aqdam1978
3589 Views, 17 Replies
I want to list all of loaded lisp programs in AutoCAD (both .lsp and .fas)
It's easy for .ARX files:
(vlax-safearray->list (vlax-variant-value (vlax-invoke-method (vlax-get-acad-object) 'listarx)))
But I don't have any idea for lisp programs, does anybody knows how can I do that?
Abbas
17 REPLIES 17
Message 2 of 18
alanjt_
in reply to: aqdam1978
Doesn't count subroutines:
(vl-remove-if-not (function (lambda (x) (wcmatch x "C:*"))) (atoms-family 1))
Message 3 of 18
aqdam1978
in reply to: alanjt_
Hi alanjt_
Thanks for your code, But I loaded a lisp program and your code could not detect it.
Message 4 of 18
BlackBox_
Beyond what Alan has already offered, I'm not sure that the LISP API has the ability to do this... Without some sort of custom .NET LispFunction Method (I'm looking into that now).
Also, as an alternative to this:
... You could simply use:
(arx)
** Note that (arx) returns all .ARX, and .DBX assemblies... For .NET assemblies, you can also try my DLL .NET LispFunction.
"How we think determines what we do, and what we do determines what we get."
Message 5 of 18
alanjt_
@aqdam1978 wrote:
Hi alanjt_
At first glance, it works for me.
What're you trying to accomplish?
Message 6 of 18
BlackBox_
@alanjt_ wrote:
@aqdam1978 wrote:
Hi alanjt_
1+... Works for me (for my loaded C: prefixed functions).
Message 7 of 18
alanjt_
in reply to: BlackBox_
Has always worked for me. That's how I protect my subroutines. I filter the atoms-family list by "AT:*" and protect the leftovers.
Message 8 of 18
hmsilva
Always worked for me too!
Henrique
Message 9 of 18
BlackBox_
Hooray - Pragma!
Boo - Autodesk Online [not-so-much-] Help!
* Wonders if this post will now show up as part of the 'Autodesk Web Results' *
#WishfulThinking
Message 10 of 18
aqdam1978
in reply to: hmsilva
Hi Henrique,
Please try my lisp code in attachement.
I cant find my lisp code using Alan's code!
Abbas
Message 11 of 18
hmsilva
Abbas,
case sensitive...
_$ (vl-remove-if-not (function (lambda (x) (wcmatch x "GETLOC*"))) (atoms-family 1))
("GETLOCALEID")
_$
Cheers
Henrique
Message 12 of 18
alanjt_
@OP, are you just trying to see if the routine is loaded?
If so, just use: (and GetLocaleID)
Message 13 of 18
alanjt_
or: (member "GETLOCALID" (atoms-family 1))
but the first is much less processiing and all you need.
Message 14 of 18
alanjt_
This is why it's also important to let us know what you are wanting this data for. We might have a beter solution.
Message 15 of 18
aqdam1978
Hi Alan,
Thanks for your good ideas,
All I am looking for is to find a solution to make a list for all .lsp/.fas loaded in AutoCAD.
I am beginner in Lisp and  I don't know is it possible via lisp or not!
Abbas
Message 16 of 18
alanjt_
@aqdam1978 wrote:
Hi Alan,
Abbas
No worries. (atoms-family-1) is going to be your best option. Out of curiousity, why do you need a list of loaded LSP/FAS files?
Message 17 of 18
aqdam1978
Hi Alan,
As I told you, I am beginner and would like to learn about lisp programming.
So, I just exploring AutoLISP and AutoCAD!
Thanks for your good information.
Abbas
(defun C:listLSP ( / lst L i S fl fn)
;(setq lst CORE-SYMBOL-LIST)
;(setq lst COM-SYMBOL-LIST)
(setq lst (vl-remove-if-not (function (lambda (x) (wcmatch x "C:*"))) (atoms-family 1)))
(setq fl (open (setq fn "List.txt") "w" ))
(setq lst (vl-sort lst '<) L (length lst) i 0 S "")
(repeat L
	(write-line (nth i lst) fl)
	(setq i (1+ i))
);repeat
(close fl)
(startapp "notepad" fn)
Message 18 of 18
alanjt_
@aqdam1978 wrote:
Hi Alan,
Abbas
(repeat L
	(setq i (1+ i))
);repeat
(close fl)
Looking good so far. Keep in mind, when stepping through a list, use mapcar + lambda or foreach (depending on your desired return). For this, I'd use foreach, since you don't care about a return list.
eg.
(defun c:Test (/ lst file fOpen)
  (if (and (setq lst (vl-remove-if-not (function (lambda (x) (wcmatch x "C:*"))) (atoms-family 1)))
           (setq fOpen (open (setq file "c:\\List.txt") "W"))
    (progn
      (foreach item (vl-sort lst '<)
        (write-line item fOpen)
      (close fOpen)
      (startapp "NOTEPAD" file)
  (princ)
State of Sustainability Webinar
AutoCAD Inside the Factory
