How to layoff all the same name layer in more xref.
ndnam7693
ndnam7693
Hello Everyone,
I'm Electrical Engineer. I've problem when I make combination building drawing. In the building have so many apart, so I need xref all Tyipcal unit part to one drawing. When I finish combine, I shall be layoff block depend on each system, such as: lighting, socket, acmv,... I layoff manual by layoff conmand that it spend so longtime, i wish I have one lisp can layoff all block the same layer at some xref in drawing.
Two 2 apartments, mean two xref file.Two 2 apartments, mean two xref file.
cadffm
Only in XRefs?
*|Layername
or current drawing and xref?
Layername,*|Layername
Try this sample for only current drawing OR xref-layer
Sebastian
ndnam7693
I've 8 xref with the same layer.I've 8 xref with the same layer.Like this. Now, I lay off it with layer manger, *LS*...
cadffm
Yes, this is solved by my sample function i post above.
This wasn't my Question, but ok. You should be happy with my first answer.
Sebastian
