How to insert a character into a string a specific location?
mid-awe
mid-awe
Hi all,
I am sure this is an easy task but I am having some trouble remembering how to insert a Letter into a string at a specific location.
I'm trying to get the (VL-FILENAME-BASE (GETVAR 'DWGNAME)) and insert a (chr 86) after the 8th character, so that the inserted letter becomes the 9th letter/number only if it is not already present.
example:
23-01472r7
becomes:
23-01472Vr7
I hope that this makes sense. Any help is greatly appreciated.
Thank you in advance.
Kent1Cooper
@mid-awe wrote:
I'm trying to .... insert a (chr 86) after the 8th character, so that the inserted letter becomes the 9th letter/number only if it is not already present.
How about something like:
(if (/= (substr YourString 9 1) "V"); not already present
  (setq YourString (strcat (substr YourString 1 8) "V" (substr YourString 9)))
If the original is not at least 9 characters long, it will simply add "V" to the end.
Kent Cooper, AIA
mid-awe
Thank you Kent, that did it perfectly.
Moshe-A
hi,
check this:
(defun insert_string (string str p)
 (if (not (vl-string-search string str))
  (if (and (not (minusp p)) (<= p (strlen string)))
   (if (= p 0)
    (strcat str string)
    (strcat (substr string 1 p) str (substr string (1+ p)))
(insert_string "23-01472r7" "V" 8)
"23-01472Vr7"
Moshe
mid-awe
Thank you Mosh for this reusable solution.
Moshe-A
thank you very much mid-awe
i forgot to insert p argument in (vl-string-search) this ensures that only if str
does not exist in the position in question the new add string is inserted.
  (if (not (vl-string-search string str p))
    (if (= p 0)
     (strcat str string)
notice that the (insert_string) function let you insert a str in front of string (p=0)
and at the end but it won't let you insert a string if the index p is out of range
moshe
mid-awe
Thanks again 🙂
