How to import csv file from sharepoint?
Message 1 of 11
I have a file in Sharepoint, a csv excel file with layers name, i need to import this to autocad to create layers list using lisp.
Help me.
Replies (10)
Message 2 of 11
dbhunia
Check >>This<< how to import CSV file....... or give a sample.......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 11
Actually I dont want to give the path every time through dialogue box to read the csv file. I want to set the path of sharepoint only once. So every time if i run the lisp it should directly read the csv from same path. I will be keep updating the csv in sharepoint.
Message 4 of 11
dbhunia
Try this.......
(defun LM:readcsv ( csv / des lst sep str )
    (if (setq des (open csv "r"))
        (progn
            (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
            (while (setq str (read-line des))
                (setq lst (cons (LM:csv->lst str sep 0) lst))
            (close des)
    (reverse lst)
(defun LM:csv->lst ( str sep pos / s )
    (cond
        (   (not (setq pos (vl-string-search sep str pos)))
            (if (wcmatch str "\"*\"")
                (list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2))))
                (list str)
        (   (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]")
                (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos)))
            (LM:csv->lst str sep (+ pos 2))
        (   (wcmatch s "\"*\"")
            (cons
                (LM:csv-replacequotes (substr str 2 (- pos 2)))
                (LM:csv->lst (substr str (+ pos 2)) sep 0)
        (   (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0)))
(defun LM:csv-replacequotes ( str / pos )
    (setq pos 0)
    (while (setq pos (vl-string-search  "\"\"" str pos))
        (setq str (vl-string-subst "\"" "\"\"" str pos)
              pos (1+ pos)
    str
Syntax.....
(setq Data_csv (LM:readcsv "CSV File path"))
or
Debashis Bhunia
Message 5 of 11
Thank you for your reply. I will try this one and tell you. Thanks one again
Message 6 of 11
I just want to add a point that my file path will be something like: https://sp.....  hope it
Message 7 of 11
dbhunia
You just run the line below in the command line.......
(getfiled "Select CSV File" "" "csv" 16)
and select the CSV file from the Dialog box ....... you will get path in your command line ...... use that as path:)
Debashis Bhunia
Message 8 of 11
ronjonp
Just a guess but you're probably going to have to download the file locally then read it. Some code HERE to do the download part.
Message 9 of 11
Good idea, i tried, i am getting nil @dbhunia
Message 10 of 11
dbhunia
What message are you getting?
Are you getting Data, while you are using the LISP like below?.....
or
How your path looks ........like "\\prt4a\SMG\Debashis\0000000.csv" or something else?
May be you should check the post as @ronjonp  said.....
Download the file & save to your local system.....& move as i said
Debashis Bhunia
Message 11 of 11
dgorsman
Or don't keep it in SharePoint.  Drawing files OK, documnets definitely.   But not data files.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
