How to generate text list in model space of all current layers
tomhY595S
tomhY595S
Hi, I'm re-working the office template, I've got approx 120 Layers. I want to be able to use/create a LISP command that essentially exports all the existing layers from the drawings into an external text/ spreadsheet file which I can then copy back in and assign each of the layers to. (alternatively, if there is a smarter way to do it am all ears.
Essentially I want to end up with all the layers with the text description and assigned properties, so we can have the info ready to match/ use in model space)
I've found a few resources but when trying to implement ran into issues that would not work - don't fully understand them so if someone can explain would great.
https://jtbworld.com/autocad-layer-list-lsp
https://www.theswamp.org/index.php?topic=45334.0
pendean
Community Legend
Community Legend
Open your layer command palette.
select ALL (CTRL+A)
CTRL+C
then CTRL+V into modelspace or whatever other application window you want to use.
Done.
Read this to learn about how to use LISP http://www.lee-mac.com/runlisp.html
tomhY595S
Hi Pendean,
Thanks for this. so it does copy them all as 1 text but as one layer too. Is there a way to have them in individual colours/layers?
Tom
(will take a look at the lee-mac link)
hak_vz
@tomhY595S
Here is code you are looking for.
It generates MText with names of all layers in current drawing colored to individual layer color.
Hope this is what you want.
Changed code
Opted for plane TEXT object since MTEXT has limit in number of paragraphs (lines)
(defun c:AllLayers ( / collectLayerObjects layerObjects layerNames colorList ts i p1)
	(defun collectLayerObjects ( / ret)
		(reverse (vlax-for lay (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'Layers)
		(setq ret (cons (cons (vlax-get lay 'Name) lay)ret))))
	(setq
		layerObjects(collectLayerObjects)
		layerNames (mapcar 'car layerObjects)
		layerObjects (mapcar 'cdr layerObjects)
		colorList (mapcar '(lambda (x)(vlax-get x 'Color)) layerObjects)
		i -1
		ts (* 1.5 (getvar 'Textsize))
	(setq p1 (getpoint "\nPick text insert point >"))
	(while (< (setq i (1+ i)) (length layerNames))
		(entmakex
			(list
				 (cons 0   "TEXT")
				 (cons 100 "AcDbEntity")
				 (cons 100 "AcDbText")
				 (cons 10 p1)
				 (cons 1 (nth i layerNames))
				 (cons 40 (getvar 'Textsize))
				 (cons 50 0)
				 (cons 62 (nth i colorList))
		(setq p1 (mapcar '- p1 (list 0 ts)))
	(princ)
Your modified file is in attachment
Miljenko Hatlak
Sea-Haven
Quick and dirty note no check for rgb colors
(defun c:Layers2csv ( /  fo )
	(setq fo (open  "D:\\acadtemp\\lays.csv" "W"))
     (write-line (strcat (vla-get-name lay) ","  (rtos (vla-get-color lay) 2 0) ","  (vla-get-linetype lay) ) fo)
   (close fo)
(princ)
(c:Layers2csv  )
Look into the =concatenate command in excel, you can make your layer changes in excel and just copy a column back to command line. Just have to get correct sequence. Use paste, special, script text.
