How to fix this code...
danglar
danglar
I tried to improve program (see attached lisp file), but have some issues with it..
This program export layout names to excel file with dimension of each layouts (paper size)
Program working properly but have a real problem with functionality. I mean program return only
Dimensions of CURRENT TAB, but I need it for each one of layouts. I think, function (papersize) working only for current tab so I can’t to invoke this function for each one of tabs..
Can somebody fix it?
Any help will be very appreciated
wispoxy
Working on it. Issue:
(vlax-for olayout olayouts
(if (/= "Model" (setq layoutname (vla-get-name olayout)))
danglar
unfortunaly your solution not working.. you can to do an experiment ( see attached lisp) with some layouts wich have different dimensions (paper sizes) but finaly you return a table with a same sizes
wispoxy
Didn't have a solution, I was just telling you what area of the code I was working on at the time.
danglar
Another way to make one step to solution of this issue is - to invoke this function instead of internal function (papersize) (see attached lisp)
But in this case I need variable as name of layout..
something like this:
(plotpapersize(layoutget "layout name"))
..and make the loop from first layoyt to last..
Can somebody help me?
