How to find layer with vport drawn?
Usually I receive drawings with frozen layer when drawn vports. The names of layer not make sense and it was difficult to turn this layer ON. In most cases I need to select all layers turn it On and only after that possible to select this layer and receive it name..
How to search this layer via lisp?
Any help will be appreciated
pbejse
In most cases its just targetting the "Viewport" entity, but there are others out there that uses Polygonal vports.
Are you just wanting to know the name? or Turn it on as well ?
pbejse
(defun c:vpl (/ vplst ss)
  (if (setq vplst nil
	    ss
	     (ssget "_X"
		    '((-4 . "<OR")
		      (-4 . "<AND")
		      (0 . "LWPOLYLINE")
		      (102 . "{ACAD_REACTORS")
		      (-4 . "AND>")
		      (0 . "VIEWPORT")
		      (-4 . "OR>")
    (progn
      (repeat (setq i (sslength ss))
	(if (and (not (member (setq vpl
				(cdr (assoc 8 (entget (ssname ss (setq i (1- i))))))
			 ) vplst )
		 (/= vpl "0")
	  (setq vplst (cons vpl vplst))
      (textscr)
      (princ"\n<<< Viewports are on the following layer(s) >>>")
      (foreach itm vplst (print itm))
  (princ)
HTH
stevor
Start with:
(setq ss (ssget "x"(list (cons 0 "VIEWPORT") )))
S
Thank you pbejse!
This is what i need:)
pbejse
@Anonymous wrote:
Thank you pbejse!
You are welcome igal1971. Glad it works for you
Cheers
