how to filter underlined MTEXTs
msarqui
Message 1 of 18
msarqui
Hello guys,
Could someone help me please.
I would like to know how to filter underlined MTEXTs in a selection set with SSGET.
I need to select MTEXTs, except those that are underlined.
Marcelo
Replies (17)
Message 2 of 18
Jonathan3891
Give this a try:
(SETQ SS (SSGET '((0 . "TEXT,MTEXT")(1 . "*%%U**%%u*,{*\L*}"))))
Jonathan Norton
Blog | Linkedin
Message 3 of 18
msarqui
Hi Jonathan
Thanks for reply but it returns nil. The selection does not select anything
I tested on the attached exemple.
Marcelo
Message 4 of 18
kerry_w_brown
Perhaps try something like
(SETQ SS (SSGET '((0 . "TEXT,MTEXT")(1 . "*%%U*,*%%u*,*{*\L*}"))))
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 5 of 18
Jonathan3891
Thats strange. It works fine on the drawing I attached, but it wont work on your drawing.
Jonathan Norton
Blog | Linkedin
Message 6 of 18
msarqui
Hi Kerry,
This is actually selecting underlined MTEXTs and I would like to exclude them. But, you show me the way and with a small change I could get it work.
Here is what I did:
(setq ss2 (ssget "_:S:L" '((0 . "*TEXT")
			    (-4 . "<NOT")
	                            (1 . "*%%U*,*%%u*,*{*\L*}")	;Avoid texts underlined
	                    (-4 . "NOT>")
			    (-4 . "<NOT")
	                            (62 . 1)			;Avoid texts in RED color
	                    (-4 . "NOT>")
Many thanks.
Marcelo
Message 7 of 18
msarqui
Well, strange it is. I did a test in your drawing and it works. I have no idea why...
Message 8 of 18
dbroad
Technically, if you only want to select MTEXT objects that have no underlined words, you would need the following:
(SETQ SS (SSGET '((0 . "MTEXT")(1 . "~*{*\L*"))))
Mtext has no uses for %%U or %%u.
If you want to select either text or mtext that is not underlined:
(setq ss (ssget	'((-4 . "<OR")
		  (-4 . "<AND")
		  (0 . "MTEXT")
		  (1 . "~*{*\L*")
		  (-4 . "AND>")
		  (-4 . "<AND")
		  (0 . "TEXT")
		  (1 . "~*%%U*,~*%%u*")
		  (-4 . "AND>")
		  (-4 . "OR>")
Architect, Registered NC, VA, SC, & GA.
Message 9 of 18
msarqui
Hello dbroad
In my tests, your suggestion will not select:
BOLD, ITALIC, UNDERLINE, OVERLINE
But it will select:
NORMAL, WIDTH, STRIKETHROUGH
Weird?
Please, see attached file
Message 10 of 18
kerry_w_brown
msarqui,
You will need to be more explicit with your question.
What test are you using exactly.
You have made no previous mention of those properties.
weird, I don't recall your original post asking for the EXCLUSION of underlined text ??
Message 11 of 18
kerry_w_brown
What is the DXF 1 value of the Mtext that is not being selected ??
Try something like this on the MText
(defun c:dxflist (/ eko)
  (setq eko (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (setq
    *lent* (entget
             (car (entsel "\nSelect entity to display its DXF value data "))
  (textscr)
  (list *lent*)
  (foreach n *lent* (print n))
  (setvar 'cmdecho eko)
  (princ)
Message 12 of 18
msarqui
@msarqui wrote:
Hello guys,
Marcelo
Hi Kerry,
Thanks for the reply.
In my first original post I DO asked for the EXCLUSION of underlined MTEXTs
In my drawings I have different types of MTEXTs formatting. Someones with BOLD, others with ITALIC, others with OVERLINE, etc.
I would like to select all of them, except (excluding) those that are underlined
In my tests, I copied and pasted @dbroad's suggestion in the command line and I selected the MTEXTS to see wich ones are highlighted.
@msarqui wrote:
Hello @dbroad
But it will select:
Weird?
I made a mistake in my last post. @dbroad's suggestion is working very well with underlined MTEXTs. Sorry about that Smiley Embarassed
The only problem is that is also excluding the BOLD, ITALIC and OVERLINED ones.
Message 13 of 18
hmsilva
Marcelo,
dbroad's filter list is correct, just add a second backslash in (1 . "~*{*\\L*")
Hope this helps,
Henrique
Message 14 of 18
doni49
Paste the following into your command line, when prompted, select one of the text elements that it's failing to select and paste the results here.
(assoc 1 (entget(car(entsel))))
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 15 of 18
dbroad
@hmsilva,
I did test it before I posted it and it did work fine with a single backslash.  It might also work fine with a second escaping backslash.
Funny what got marked as a solution.  Oh well.
Message 16 of 18
hmsilva
@Anonymous wrote:
@hmsilva,
@dbroad,
I did test with the dwg in msg#9 and only with a second backslash works as expected...rejecting underlined text...
I did also test in others dwgs, and with a single backslash works as expected, and with double backslashes works as expected also...
Being transversal to several tests, the 'double backslashes' in the list, do you mind to add a second backslash to your code, to provide a more universal solution?
Henrique
Message 17 of 18
dbroad
Interesting.  I missed that post.  Thanks for adding the extra backslash!
Message 18 of 18
hmsilva
You're welcome, dbroad!
Henrique
