How to extract parts of the route on lisp ?
Hi people, this my first post here i have read you months ago, now i wanna to clear some things.
What i want to do is the following:
Using lisp i wanna extract parts of the route, by example:
The route of draw is "C:\XXX\Works\DUSTIN\JUNE\example.dwg"
I want to separate the route into 5 variables:
var1 = XXX
var2 = Works
var3 = DUSTIN
var4 = JUNE
var5 = example.dwg
Another thing that I would like to find out is to know if I have these variables I can complete attributes of a block in an automated or semi automated way. Example:
ATTRIBUTES (All are in 1 block):
ROUTE1: fill this attribute with "var1"
ROUTE2: fill this attribute with "var2"
LKD: fill this attribute with "var3"
DATE02: fill this attribute with "var4"
DRAW: fill this attribute with "var5"
Thats all for me, i want to thank you in advance..
PD: Sorry for my english, is not good, but in spanish forum i havent a clear answer.
ronjonp
How familiar are you with lisp?
Here is a start to your question:
(defun _parse (str del / i)
  (if (setq i (vl-string-search del str))
    (vl-remove "" (cons (substr str 1 i) (_parse (substr str (+ i 1 (strlen del))) del)))
    (list str)
;; Parse path and remove drive
(setq l (cdr (_parse (strcat (getvar 'dwgprefix) (getvar 'dwgname)) "\\")))
;; Bind parts of list to variables
(mapcar 'set '(var1 var2 var3 var4 var5) l)
Hi, Ron, thanks for the prompt response.
I need to told you this is my first lisp code, i only do some small things in the command line of AutoCAD.
I going to test what you just passed and analyze in cold because i do not understand it at all, I need to look for each command (i call command to "str", "substr", "defun") to know what it does and how it works as well as the structure. Again, I thank you.
PD: Do you have a link to the explain to all "commands" ? (i know they arent commands, whats the correct word ?)
ronjonp
HERE is a good start to learn the functions. 🙂
If you post a sample drawing with your block I can help you more.
Ron, here is the block i'll fill with the bars... following the example:
ATTRIBUTES OF THE BLOCK:
RUTA-1: fill this attribute with "var1"
RUTA-2: fill this attribute with "var2"
PLANO-N: fill this attribute with "var5"
The others do not need to be completed automatically or complete them with DIESEL fields.
ronjonp
I ran out of time today but I'll get something together in the next few days.
Dear Ron.
I'm happy to tell you I could do what I was looking for.
I answer if you were still working on it; and to clarify what I did in case some other user was looking for something similar.
the code he used was:
(defun c:FHEREDIA() ;just example haha
;;;;; COMIENZO DE LA RUTINA ;;;;;
; - LLAMADO DE LA RUTA - ;
(setq _ruta (substr (getvar 'dwgprefix) 37)
;I DESIRE THE FIRST 36 CHARACTERS, BECAUSE THEY ARE PART OF
;MY SERVERS ROUTE AND ARE THE SAME FOR ALL MY FILES
;\\SERVER\tecnica\AUTOCAD_1\
;AND THE CHARACTER NUMBER 37 BECAUSE I DELETE THE FIRST SLASH
(setq nruta1
;COUNT THE CHARACTERS UNTIL THE NEXT SLASH
(vl-string-search "\\" _ruta 2)
(setq ruta1
(substr _ruta (+ nruta1 1))
;CUTTING THE ROUTE WITHOUT THE FIRST ITEM I ALREDY
;KNOW HOW TO CUT IN "Cliente"
(setq nruta2 ;repeat
(vl-string-search "\\" ruta1 2)
(setq ruta2 ;repeat
(substr ruta1 (+ nruta2 1))
(setq cliente ;set and cutting at 16characters
(if
(<= (strlen (substr _ruta 1 nruta1)) 16)
(strcat (substr _ruta 1 16) "...")
(setq presupuesto (substr ruta1 2 (- nruta2 1))) ; set
(setq estado (vl-string-trim "\\" ruta2)) ; set
;;;;; FIN DE LA RUTINA ;;;;;
Thats all.. i calling the variables with DIESEL
%<\AcVar.17.0 Lisp.cliente>%
%<\AcVar.17.0 Lisp.presupuesto>%
%<\AcVar.17.0 Lisp.estado>%
I'm doubting if that .17 takes into account that my autocad is 2017 and will not work correctly in other versions.
And that would be all I did so far, although it is a pretty beginner code, it helped me a lot.
I wanted to thank you for the link you sent me about the functions, it was very helpful.
Greetings.
