how to export co-ordinates to excel CSV file?
Dear all,
          i want to export auto cad co-ordinates to excel. please any one send the  lisp file for this type.
herewith i attached i needed lisp type.   i need to show that co-ordinate number vise and csv format also. please anyone help me to find a solution.
dbhunia
what I get from your post....
1   "01, 02,03..." all are blocks with a single attribute.
2   The X-coordinate is NORTHING & Y-coordinate is EASTING
If so try this.....
(defun C:MC (/)
(setq BN (getstring "\nEnter the block Name to Select: "))
(Setq selectionset (ssget "_A" (list (cons 0 "insert")(cons 2 BN))))
(setq Text "POINTS,EASTING,NORTHING")
(repeat (setq N (sslength selectionset))
	(setq Data (ssname selectionset (setq N (- N 1))))
	(setq EntityData (entget Data))
	(setq IP (cdr (assoc 10 EntityData)))
	(setq elst(entget(entnext Data)))
	(setq AT (cdr (assoc 1 elst)))
	(setq Text (strcat text "\n" AT "," (rtos(nth 1 ip)) "," (rtos(nth 0 ip))))
(setq fn "C:\\output.csv"
     fp (open fn "w")
(write-line text fp)
(close fp)
It will create a file at "C:\\output.csv".....
Only things you have to do.......
1   To enter the block name.
2   To sort the generated *.cvs file (to the column points)......
Hopefully you can manage the rest.......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
If so try this.....
(defun C:MC (/)
     fp (open fn "w")
(close fp)
dear sir,
            i'm not a expert. so how to use this coding in autocad.
dbhunia
If you go through online you should get how to load a .lsp file & run it ........ ok....
1   First copy & paste the entire code into notepad & save it with some name with "LSP" extension .........(like "XXX.LSP")
2   Type command "APPLOAD" you should get the window.....(this window for AutoCAD 2007, this differs on version)
3   Now select the saved "*.lsp" (say XXX.LSP) file from your saved location & press "Load" button & close the window...
4   Now put the command "MC" & press enter ....... the code will run......
Debashis Bhunia
