Calculate area in % Meter Square for Object inside Flexible Routing
ndnam7693
Message 1 of 14
ndnam7693
Hello Everyone,
I'm ME Engineer. Now I'm draw shop drawing for Underground Pipe for Electric Incoming System. Electric Cable inside  HDPE Flexible Pipe. But Consulting Team of Client requested me that they want to indicated % Meter Square for Object inside Flexible Routing. Help me! Thanks.
Replies (13)
Message 2 of 14
ВeekeeCZ
It's hard to say in which units you're in, so adjust the measurement.
(vl-load-com)
(defun c:LabelAreaPerc ( / dst anf obj sel obj aro ari pnt)
  (and (setq dst 1.00
             ang 1.57)
       (setq sel (nentsel "\nSelect outer circle: "))
       (setq obj (vlax-ename->vla-object (car sel)))
       (or (not (vl-catch-all-error-p (setq aro (vl-catch-all-apply 'vla-get-area (list obj)))))
           (prompt "\nWrong selection. Area property is not available!"))
       (vl-cmdf "_.MLEADER"
                "_none" (setq pnt (vlax-curve-getclosestpointto obj (cadr sel)))
                "_none" (polar pnt ang dst)
                (strcat (rtos aro 2 1) "m2"))
       (setq sel (nentsel "\nSelect inner circle: "))
       (or (not (vl-catch-all-error-p (setq ari (vl-catch-all-apply 'vla-get-area (list obj)))))
                (strcat (rtos ari 2 1) "m2 - " (rtos (* 100 (/ ari aro)) 2 0) "%")))
  (princ)
Message 3 of 14
ndnam7693
Firstly, Thank for help. But I've some problem when using your lisp. Please see at attach pics. Dimension show at ucs (0,0,0). Almost, I create block and change base point to center of Object then I dimension and it's working but show wrong position. Other one I don't change base point, Your lisp working smoothly. Help me If you can resolve.
Message 4 of 14
ВeekeeCZ
Sure, no trouble.
(vl-load-com)
(defun c:LabelAreaPerc ( / dst ang obj sel obj aro ari pnt)
  (and (setq dst 1.00
             ang 0.79)
                "_none" (setq pnt (trans (vlax-curve-getclosestpointto obj (trans (cadr sel) 1 0)) 0 1))
  (princ)
Message 5 of 14
ndnam7693
Sorry, but I cannot dimension with right position. :(. Plz check my file, maybe you can get some idea for resolve.
Message 6 of 14
ВeekeeCZ
Now you see how important is always post a test dwg.
(vl-load-com)
  (and (setq dst 10.00
             ang 0.79)
                "_none" (setq pnt (osnap (cadr sel) "_nea"))
  (princ)
Message 7 of 14
ndnam7693
Thank bro, It's work perfect. Many thanks to you.
Message 8 of 14
k_ngo-quoc
Your lisp is perfect! I usually work with mm. Is it possible to transform the area in m² and the mleader as "TEST" style.
Thanks advance.
My file in attach.
Message 9 of 14
ВeekeeCZ
Here you go. Only thing is that you should adjust your Test DimStyle, its Text / Vertical Text Placement to Above.
(vl-load-com)
(defun c:LeaderArea ( / dst ang obj sel obj aro ari pnt)
  (and (setq dst 1500.00
             ang 0.79)
       (vl-cmdf "_.-DIMSTYLE" "_Restore" "Test")
       (setq sel (nentsel "\nSelect object: "))
       (vl-cmdf "_.LEADER"
                "_none" "@550,0"
                (strcat (rtos (/ aro 1000000) 2 1) "m2")
  (princ)
Message 10 of 14
Can you adjust a little bit for suite ?. When I pick select 1 outlet circle and then pick 1 inner. But it so spend time when i need pick many inner inside 1 outlet circle. I wanna pick 1 outlet circle and many inner circle?. Thanks
Message 11 of 14
ВeekeeCZ
Gee... how many of you are up there?
(vl-load-com)
(defun c:LabelAreaPercM ( / dst ang obj sel obj aro ari pnt)
             ang 0.79)
       (while (setq sel (nentsel "\nSelect inner circle: "))
         (and (setq obj (vlax-ename->vla-object (car sel)))
                       (strcat (rtos ari 2 1) "m2 - " (rtos (* 100 (/ ari aro)) 2 0) "%")))))
  (princ)
Message 12 of 14
k_ngo-quoc
Thanks for transforming in m². But it missed the second click (%).
Thanks in advance for your help.
Message 13 of 14
ВeekeeCZ
Sorry about that, misunderstanding. I got it back.
; **** LEADER VERSION ****   ; + CONVERSION MM TO M
(vl-load-com)
             ang 0.79)
       (setq sel (nentsel "\nSelect outer area: "))
       (vl-cmdf "_.LEADER"
                "_none" "@550,0"
       (while (setq sel (nentsel "\nSelect inner area: "))
              (vl-cmdf "_.LEADER"
                       "_none" "@550,0"
                       (strcat (rtos (/ ari 1000000) 2 1) "m2 - " (rtos (* 100 (/ ari aro)) 2 0) "%")
  (princ)
Message 14 of 14
k_ngo-quoc
Perfect! Thanks!
