How to expand .lsp file function from currently open drawing to whole project?
iedwards17
iedwards17
I'm super new to all of this, so I'm sorry if it seems like a stupid question. I am writing a LISP file that exports all blocks' x and y position data in the currently open AutoCAD Electrical drawing. Is there a way to change it from the currently open drawing to iterating or looping through all of the drawings in a specific folder or .wdp project file?
Here is my current code:
(defun c:ExportBlockPositionData ()
(setq file (getfiled "Select File to Save" "" "csv" 1))
(setq blk_list '())
(setq ss (ssget "_X" '((0 . "INSERT"))))
(if ss
(progn
(setq count (sslength ss))
(setq output_string "Block Name,X Position,Y Position\n")
(setq i 0)
(while (< i count)
(setq blk (ssname ss i))
(setq blk_name (cdr (assoc 2 (entget blk))))
(setq blk_pos (cdr (assoc 10 (entget blk))))
(setq output_string (strcat output_string blk_name "," (rtos (car blk_pos) 2 2) "," (rtos (cadr blk_pos) 2 2) "\n"))
(setq i (1+ i))
(setq file_id (open file "w"))
(write-char (ascii "sep=,\n") file_id) ; Excel separator
(write-line output_string file_id)
(close file_id)
(princ "\nBlock position data exported successfully.")
(princ "\nNo blocks found in the drawing.")
(princ)
paullimapa
Excellent question. You'll just have to Script this on all of drawings in a folder.
First of all for this code to run in a Script you just need to change this line which brings up a selection window:
To this line which just uses the drawing folder & file name as the csv file:
(vl-load-com)(setq file (strcat(getvar "dwgprefix")(vl-filename-base (getvar"dwgname")) ".csv") ; saves csv file matching folder & drawing name
Next install something like Script Writer which allows you to run a series of commands on all drawings in a selected folder:
In your case the Script Line in the above window would look something like this:
_.Open *file* (load"ExportBlockPositionData") ExportBlockPositionData _.Close
Paul Li
IT Specialist
@The Office
iedwards17
@paullimapa Thank you!
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Sea-Haven
If you want 1 file across multi dwg's, add dwg name to file output you can use "A" rather than "W" for file, "A" is append, but you will need to probably for simplicity hard code an output filename. A side note if to Excel is required could write direct to Excel.
