how to end object selection in autolisp
Very new to autolisp.  Very simple question here frustrating the heck out of me.
I am trying to select all objects.   It selects all objects but I cannot figure out how to tell it I am done selecting.   In commandline you just press enter and that tells it you are done selecting, but in autolisp it doesnt work
I have tried all of the following;
(command "_SELECT" "ALL" "")
(command "_SELECT" "ALL" " ")
(command "_SELECT" "ALL" "" "")
(command "_SELECT" "ALL" "\n")
(command "_SELECT" "ALL" "\r")
(command "_SELECT ALL \n\n")
None of those work.   In all cases it says "Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle/SUbobject/Object
Autolisp error: Function cancelled"
It then ends the function and command line resumes with a prompt to continue selecting objects
How to convince it that I am really done selecting objects?
RedMan77
Maybe we can see your full code for the routine so we can see what you are trying to do to ensure the proper syntax is being used.
Kent1Cooper
None of those work.   In all cases it says "Expects a point or ....
That first one works for me.  Check whether it's giving you that error message in response to the "ALL" or the "" -- might it be a question not of how to tell it you're done, but possibly that somehow it's not accepting the "ALL" as input, that is, the first part is the problem, not the last part?.  In case there might be an undefinition and new definition of the Select command involved, or a language-version issue, try forcing the native command definition [the period prefix] and covering the other-than-English-version possibility for the All option:
(command "_.SELECT" "_ALL" "")
Kent Cooper, AIA
hmsilva
Hi jdwpv4,
try this demo
(defun c:demo (/ echo)
  (setq echo (getvar 'CMDECHO))
  (setvar 'CMDECHO 1)
  (command "_SELECT" "_ALL" "")
  (setvar 'CMDECHO echo)
  (princ)
if it works as expected, you must ensure CMDECHO is '1' when you call the 'select command.
Hope this helps,
Henrique
Hi All,
Thank you for your replies.  I found the problem; Redman was the closest to the answer.    The problem was in another command.
What I was trying to accomplish was to blank the entire drawing.  So following the select all command was an erase command.   If you were using autocad in the command line the commands would have been
SELECT
ALL
ERASE
and of course in autocad that will select everything and erase them.    However evidently AutoLisp does not emulate autocad faithfully.
I had
   "ERASE"
It turns out that it was the ERASE that was causing the problem.   Evidently AutoLisp does not understand that the ERASE command is to operate on the selection set of the previous line.   ERASE was expecting its own selection.
I changed it to
"ERASE" "ALL" ""
and that worked.   Of course that made the select command redudant, so I then changed it to
(command "ERASE" "ALL" "")
And all is happy.
Thanks for your time!
Kent1Cooper
SELECT
ALL
ERASE
and of course in autocad that will select everything and erase them.  ....
....   Evidently AutoLisp does not understand that the ERASE command is to operate on the selection set of the previous line.   ERASE was expecting its own selection.
SELECT does not leave everything selected/highlighted.  It only puts things into what becomes the Previous selection.  Your command-line usage example does not work for me.  If I type Erase immediately after typing All, it's still waiting for further selection, and the word "erase" is invalid for that.  If I complete the selection with another Enter after giving it the All option, it goes back to the Command: prompt, and a following Erase command has no relationship to the Select results unless given the Previous option.
If you select everything with a big window rather than using a Select command, and then [with everything highlighted] type Erase, it will do it [assuming you have the PICKFIRST System Variable set appropriately].
You are quite correct that "AutoLisp does not understand that the ERASE command is to operate on the selection set of the previous line," because your code did not tell it to, and that Erase expects its own selection.  The correct construction [I'm not suggesting you use it here, but if you find some other application in which using Select first is appropriate] would be:
(command
  "_SELECT" "ALL" ""
  "ERASE" "P" ""
Kent Cooper, AIA
RedMan77
Glad I could help if only in a small way.  Most of my issues are syntax issues.  I am still learning.
