How to edit the attribute values using AutoLisp
I want to change the values of a list of attribute tag's using to 'tagvalues' list.
the below program is to change the value of all attribute tag's to 'Nil'...
Can someone suggest how to rearrange this program to achieve it?
                    (setq tags (list "DRAWING_#" "V" "PH" "HZ" "SIZE"))
                     (setq tagvalues (list "A" "B" "C" "D" "E"))
                    (setq
                    ss (ssget "_x" (list '(2 . "TITLE_BLOCK_B-1")))
                    i 0
                    (repeat (sslength ss)
                    (setq
                    obj (vlax-EName->vla-Object (ssname ss i))
                    lstatts (vlax-SafeArray->list (variant-Value (vla-GetAttributes obj)))
                    (foreach atts lstatts (if (member (vla-Get-TagString atts) tags)(vla-put-textstring atts "")))
                    (setq i (1+ i))
Thanks in advance.
Accepted solutions (3)
@Anonymous Test this: http://www.lee-mac.com/batte.html
_gile
You shoud use an association list (e.g., a list of dotted pairs) instead of two separate lists.
(setq tagvalues '(("DRAWING_#" . "A") ("V" . "B") ("PH" . "C") ("HZ" . "D") ("SIZE" . "E")))
(setq
  i  0
  (setq
    (if (setq pair (assoc (vla-Get-TagString atts) tagvalues))
      (vla-put-textstring atts (cdr pair))
  (setq i (1+ i))
Another way using the setpropertyvalue function:
(if (setq ss (ssget "_x" (list '(2 . "TITLE_BLOCK_B-1"))))
  (repeat (setq i (sslength ss))
    (setq block (ssname ss (setq i (1- i))))
    (foreach pair tagvalues
      (vl-catch-all-apply 'setpropertyvalue (list block (car pair) (cdr pair)))
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
jayhar
Find the attachment
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Hi Gilles &  Jayhar,
Thanks for your quick response and it works well..
And sorry for the delayed communication.
How to add a variable instead of values to paired list ?
(setq tagvalues '(("DRAWING_#" . VARAIBLE1) ("V" . VARIABLE2) ("PH" . "C") ("HZ" . "D") ("SIZE" . "E")))
_gile
(setq tagvalues
(list
(cons "DRAWING_#" VARAIBLE1)
(cons "V" VARIABLE2)
(cons "PH" "C")
(cons "HZ" "D")
(cons "SIZE" "E")
Gilles Chanteau
GileCAD
GitHub
