How to display the total lenght by dyn(F12)?
Message 1 of 8
Good morning.I'm from China.I want to ask a question.Thanks in advance and forgive my poor English.
After turning on the dyn(F12), a running total of the distance will display beside the mouse pointer when I use DIST (M) command.
Until now,I only know how to display the text beside the mouse pointer by getXXX function,in the meantime,only grread funtion can obtain the real-time mouse position.But they cannot be used at the same time.
Finally,How the DIST (M) command get the real-time  mouse position information and display it by dyn(F12) beside the mouse pointer .
Can anyone help? Please~~~~~
Replies (7)
Message 2 of 8
Up!!!Anybody here???
Message 3 of 8
BeKirra
Hi, both "dist" command and "getdist" function measure the distance between 2 points. They don't measure the total length of a polyline.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 4 of 8
Thanks for reply,you can try the way to measure the total length of a polyline that  following the step  1."dist"  2.input a point  3."M" .
Message 5 of 8
BeKirra
Sorry, you're right. I am old school - learned it then never looked back after decade...
Can you show your code here so your question would be better understood?
BTW Here is a kind suggestion as I see you are a new member here. You may also post your questions in 中文 forum - Just ask your questions where you like.
https://forums.autodesk.com/t5/autocad-zong-he-tao-lun-qu/bd-p/923
X² + Y² = C²
Message 6 of 8
(defun c:d()
 (vl-cmdf "dist" pause "M")
Hey friend,it's the code.But I want to get the point to entmake a lwpolyline.
For example,
(defun c:tt ()
 (setq pt1 (getpoint))
 (setq pt_list '(pt1))
 (command "dist" pt1 "m")
 (while (= 1 (getvar "cmdactive"))
 (command pause)
 (setq pt1(getvar "lastpoint"))
 (setq pt_list (cons pt1 pt_list))
 pt_list
I can get the  pt_list ,but can not get the real-time length.
I only can get the real-time length by the function "grread",but can not display it beside the cross cursor like the "dist" do.
I only want to know how the "dist" make use of dyn mode (F12) to display the message.
I already ask this question in Chinese forum,but nobody know.
http://bbs.mjtd.com/thread-176461-1-1.html
Message 7 of 8
knock knock knock
Message 8 of 8
ВeekeeCZ
HERE from the Lee's code you can pick up the principle.
