Visual LISP, AutoLISP and General Customization
HOW TO CREATE TABLE IN DCL TO LOOK FORMATTED ON THE AUTO CAD SCREEN
1 REPLY 1
rolisonfelipe
302 Views, 1 Reply
EXECUTAR_BLOCO : dialog
{label = "BLOCO";
:boxed_column{
: edit_box {key= "IDEVER" ;edit_width=200;alignment=left;}
: text {value= "/FAMILIA BLOCO ESTRUTURAL///////////////////////////////////////////////////////////////////////////////////////////////";alignment=left;}
:column{
: text {value= "|-----------------------------+-------+---------------+-------------------------------+---------------+---------+";alignment=left;}
: text {value= "| |NOMINAL | 20 | 15 | 12,5 | 10 | 7,5 |";alignment=left;}
: text {value= "| |MÓDULO | M-20 | M-15 | M-12,5 | M-10 | M-7,5 |";alignment=left;}
: text {value= "| DESIGNIAÇÃO |ARMAÇÃO | 1/2 | 1/2 | 1/2 | 1/2 | 1/2 | 1/2 | 1/2 | 1/2 | 1/2 |";alignment=left;}
: text {value= "| |LINHA | 20X40 | 15X40 | 15X30 | 12,5X40 | 12,5X25 | 12,5X37,5 | 10X40 | 10X30 | 7,5X40 |";alignment=left;}
: text {value= "|-----------------------------+-------+-------+-------+---------+---------+-----------+-------+-------+---------|";alignment=left;}
: text {value= "| ALTURA cm | 19 | 14 | 14 | 11,5 | 11,5 | 11,5 | 9 | 9 | 6,5 |";alignment=left;}
: text {value= "| LARGURA cm | 19 | 19 | 19 | 19 | 19 | 19 | 19 | 19 | 19 |";alignment=left;}
: text {value= "| |INTEIRO | 39 | 39 | 29 | 39 | 24 | 36,5 | 39 | 19 | 39 |";alignment=left;}
: text {value= "| |MEIO | X | 14 | 19 | 19 | 11,5 | X | 19 | 9 | 19 |";alignment=left;}
: text {value= "| | 2/3 | X | X | X | X | X | 24 | X | X | X |";alignment=left;}
: text {value= "| | 1/3 | X | X | X | X | X | 11,5 | X | X | X |";alignment=left;}
: text {value= "| COMPRIMENTO |ARMAÇÃO L | X | 34 | X | X | X | X | X | X | X |";alignment=left;}
: text {value= "| |ARMAÇÃO T | X | 54 | 44 | X | 36,5 | 36,5 | X | 29 | X |";alignment=left;}
: text {value= "| |COMPENSADOR A | 90 | 90 | X | 90 | X | X | 90 | X | 90 |";alignment=left;}
: text {value= "| |COMPENSADOR B | 40 | 40 | X | 40 | X | X | 40 | X | 40 |";alignment=left;}
: text {value= "| PESO UNITÁRIO EM KG | 16,2 | 13 | 8,7 | 10,4 | 5,6 | 9 | 8 | 3,6 | X |";alignment=left;}
: text {value= "| QUANTIDADE POR M2 | 12,5 | 12,5 | 16,6 | 12,5 | 20 | 13,3 | 12,5 | 25 | X |";alignment=left;}
: text {value= "//////////////////////////////////////////////////////////////////////////////////////////////" ;alignment=left;}
:row{ label="";
:row{
: image { key = "imm" ;height = 1.0 ;width = 1.0;}
: paragraph {
: text_part {label = "STANDARD ENGENHARIA ||| | | | |";}
: text_part {label = "Projetos e Consultoria";}}}
:row{
HOW TO KEEP THIS FORM IN DCL, THIS IS AN ADVISORY TABLE FOR PROJECTS
THANK YOU TO EVERYONE WHO CAN CONTRIBUTE
ok_only;
1 REPLY 1
john.uhden
in reply to: rolisonfelipe
@rolisonfelipe
You may not have enough screen width to reproduce that via DCL.
Here's a snip of the most organized one I've done.
Hmm, I think I made it when we were running 1024x768, so it looks like there's a lot of room left after all (at 1920x1080)
John F. Uhden
Technology Administrators
