how to create Dimensions in given chainage with given depth?
sharmaudit1189
Message 1 of 17
sharmaudit1189
I have one excel with chainage and Depth. I want to create dimension with specific chainage as per output.
If anyone help me than it would be great.
Thanks in advance
Input:
Output :
Replies (16)
Message 2 of 17
Moshe-A
@sharmaudit1189  hi,
Attached cdepth.zip contains 5 files:
cdepth.lsp => the program
cdepth.csv => data csv (excel) file
arr0.dwg => block
arr1.dwg => block
gl.dwg => block
make a new folder and extract these files inside
add this folder to AutoCAD support files search path
load the lisp invoke CDEPTH command
some info were missing:
1. your csv data file?
2. the distance between stations?
3. the overall scale?
4. some layers?
enjoy
Moshe
Message 3 of 17
sharmaudit1189
CSV as look like in input
3mtr
1
4. some layers?
Message 4 of 17
sharmaudit1189
Thanks for your effort @Moshe-A, But its not work as per output.
Message 5 of 17
Moshe-A
@sharmaudit1189 hi,
1. help me to understand what to do with the above reply???
2. took you 4 days to reply, so you competly not interested in this lisp.
send your csv
3 m does not correlate to your picture
adding text to drawing must be subject to plot scale (can not be 1)
privide your layers name
Moshe
Message 6 of 17
sharmaudit1189
Please find attached csv file
Message 7 of 17
sharmaudit1189
Here is ground level as a chainage 3,6,9,12.....
and depth from ground level which we need in dimension below to the ground.
Only ground line and chainage text and dimension below to ground level is best to this profile
Thanks in advance
Message 8 of 17
Moshe-A
@sharmaudit1189
give this a try
a sample run is also attached
works?
Message 9 of 17
sharmaudit1189
Thanks for your effort but in this lisp, we have to add each an every value. Could it be possible in automatics (all dimensions are create in one time)
Message 10 of 17
sharmaudit1189
I want to place dimension here from csv in equal (3mtr) distances.
Message 11 of 17
Moshe-A
@sharmaudit1189 ,
On message #4 you said it does not work, before you jump to more request i want to know does the last version works as you request in message 1?
Message 12 of 17
komondormrex
check this one
(defun c:dim_chainage (/ csv_file_id chain chain_depth_list chain_origin chain_pline depth_pline chain_vertices depth_vertices ruc dimension alignment_point chain_text)
  	(setq csv_filename (acet-ui-getfile "Select Chainage/Depth CSV filename"
					     "csv"
					     2
  	      csv_file_id (open csv_filename "r")
  	(read-line csv_file_id)
	(while (setq chain (read-line csv_file_id))
		(setq chain_depth_list (append chain_depth_list (list (read (strcat "(" (vl-string-translate "," " " chain) ")")))))
  	(close csv_file_id)
  	(setq chain_origin (getpoint "\nPick point for chain origin: ")
	      chain_pline (vla-addlightweightpolyline (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
						      (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 1 (* 2 (length chain_depth_list))))
									   (apply 'append (setq chain_vertices (mapcar '(lambda (chain) (mapcar '+ chain_origin (list (car chain) 0))) chain_depth_list)))
	      depth_pline (vla-copy chain_pline)
  	(vla-put-coordinates depth_pline
			       			  (apply 'append (setq depth_vertices (mapcar '(lambda (chain) (mapcar '+ chain_origin (list (car chain) (* -1 (cadr chain))))) chain_depth_list)))
  	(vla-put-color chain_pline 1)
  	(vla-put-color depth_pline 2)
  	(mapcar '(lambda (dim_point_1 dim_point_2 number) (progn
								(setq dimension (vla-adddimrotated (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
										     		   (vlax-3d-point dim_point_1)
										     		   (vlax-3d-point dim_point_2)
										                   (* 0.5 pi)
							    	(vla-put-color dimension 3)
							    	(vlax-put dimension 'extline1suppress 1)
							    	(vlax-put dimension 'extline2suppress 1)
							    	(vla-put-arrowheadsize dimension 1.0)
							    	(vla-put-textheight dimension 0.75)
							     	(vlax-put dimension 'textinside 1)
							    	(vlax-put dimension 'textinsidealign 1)
							    	(vlax-put dimension 'forcelineinside 0)
							    	(vlax-put dimension 'suppresstrailingzeros 0)
							     	(vla-getboundingbox (vlax-ename->vla-object (entlast)) nil 'ruc)
								(setq chain_text (vla-addtext (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
										  	      (itoa (car number))
										  	      (setq alignment_point (vlax-3d-point (list (car dim_point_1) (+ 0.25 (cadr (vlax-safearray->list ruc))))))
										  	      0.5
							    	(vla-put-color chain_text 7)
								(vla-put-alignment chain_text 1)
							    	(vla-put-textalignmentpoint chain_text alignment_point)
		 chain_vertices
		 depth_vertices
		 chain_depth_list
	(princ)
Message 13 of 17
sharmaudit1189
Yes but in one time one dimension is create. So please guide me that create profile in one time.
Message 14 of 17
sharmaudit1189
Thanks for your effort but when i run this lisp only pline is create.
I want create dimension ever 3 mtr as per defined in csv.
Message 15 of 17
komondormrex
if it does not draw dimensions than it should stop with an error which is output in the text window. what is it?
this is what i've got on my side using your csv.
Message 16 of 17
sharmaudit1189
Lot of Thanks @komondormrex, its works
Message 17 of 17
sharmaudit1189
Could you please edit this, which is work from excel also.
Thanks and regards
