how to create and use variables in autoCAD
joseph_filbert1
Message 1 of 12
joseph_filbert1
Community Visitor
Community Visitor
I cannot seem to figure out how to "use" variables in autoCAD. I am very new to the software, but I have some experience with other CAD software (Onshape). Reading through the help file, I found that I can define a user parameter using the parameter manager. However, I'm not sure how to "use" this parameter. For example, I want to create a UCS which is offset from the WCS by some calculated value <0.5*VAR1+(9*0.010+3*0.005)*25.4,0,0>
1) Can you use formulas when creating stuff this way?
2) Is there a way to create the variable on the fly?
Replies (11)
Message 2 of 12
CodeDing
There are ways to dynamically create the position of the UCS. Most notably would probably a Lisp command/function. I do not know of a way to dynamically adjust the UCS position via parameters though (AutoCAD "parameters" are unique entities within the environment, compared to "parameters" often used within programming languages).
How do you visualize creating / updating this variable "on-the-fly"? By running a command? Pushing a button? A popup box? Calculated from something in the DWG?
Best,
~DD
Message 3 of 12
joseph_filbert1
Community Visitor
Community Visitor
I am unfamiliar with LISP commands, this seems a bit heavy to allow for a variable to be used when setting the origin of a UCS. I would like to be "lazy" and have the required value calculated by autoCAD instead of me. Am I approaching this incorrectly?
In other CAD packages if you reference an undefined variable you are given a prompt to define the variable at that moment. Instead of creating the variable ahead of time through the parameter manager.
Message 4 of 12
autoid374ceb4990
So in your example if VAR1 is 10.0 you want the UCS set to 7.667,0,0 ?
Do any of the other numbers in your equation change or just VAR1?
Message 5 of 12
joseph_filbert1
Community Visitor
Community Visitor
In this example, just VAR1 would be some predefined value. This would apply to other objects that I want to create. Say the starting point of a line, is it possible to use a formula which references a user parameter. Or should I create a random line then impose a formula based geometric constraint afterwards?
Message 6 of 12
DGCSCAD
Dive into "The Basics in a Nutshell" to get a better understanding of how LISP works: https://www.afralisp.net/
AutoCad 2018 (full)
Win 11 Pro
Message 7 of 12
paullimapa
Not sure if what you want can be done but to give you an idea as to what I know here are the steps to get the x, y, z coordinates of the start point of a LINE
You can enter the following at the command prompt:
1) Select the LINE object:
(setq line-entity nil)(while (not line-entity) (princ "\nSelect a Line...") (setq line-entity (ssget "_+.:E:S" '((0 . "LINE")))))
line-entity is the variable that represents the selection set
2) Get the starting point x, y, z coordinates:
(if line-entity (progn (setq line-entity (ssname line-entity 0) ptx (getpropertyvalue line-entity "StartPoint/X") pty (getpropertyvalue line-entity "StartPoint/Y") ptz (getpropertyvalue line-entity "StartPoint/Z"))))
line-entity is the variable that represents the LINE entity which is the first item in the selection set
ptx is the variable that represents the LINE's starting X coordinate
pty is the variable that represents the LINE's starting Y coordinate
ptz is the variable that represents the LINE's starting Z coordinate
3) To use ptx variable like VAR1 for the new X coordinate of the UCS origin location along with pty as the Y coordinate and ptz as the Z coordinate:
(command "_.UCS" "_ZA" (list (+ (* 0.5 ptx) (* (+ (* 9 0.010) (* 3 0.005) 25.4))) pty ptz) "")
Paul Li
IT Specialist
@The Office
Message 8 of 12
Sea-Haven
Sounds to me that you need to study up a little bit about the UCS command. They can be set using lisp.
If you have an object a valid command sequence is  UCS OB pick object say a line at end. You can then run UCS again and set say the slope angle in say the X plane.
Another is UCS 3. Which sets 3 points for the UCS. There is multiple ways to set a UCS and you can save current UCS by just that UCS S. Use UCS R to get it back.
Dont forget to type PLAN after setting a UCS.
Use UCS W to reset back to world then type PLAN.
Message 9 of 12
leeminardi
One option is to use quickcalc. Set a constant then use it in an expression.  For example,  in the following I've defines a constant named  var1 and set it to 10.
When typing the expression for a point star with a square bracket. The "10" you see in the expression below was entered by double clicking var1 uder New Category.
After hitting Enter you get the following:
You can copy/paste the result of the calculation;  7.667,0 into the prompt line.
lee.minardi
Message 10 of 12
tramber
By the way, @leeminardi , this is also possible with the 'CAL function 😁
Old and fun (because you can interact with osnaps) but sometimes very practical, it can store variables through lisp
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-B29F2EF7-12C8-423C-91F5-3852E6AF1514
To explore a little...
Message 11 of 12
CGBenner
@joseph_filbert1
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 12 of 12
joseph_filbert1
Community Visitor
Community Visitor
This seems to be the closest to what I would like to do.
