How to create a table with first 2 rows as titles?
kevinlZL4WG
kevinlZL4WG
As the title states above, I am trying to create a table with the first 2 rows as title rows. Do you guys know how to do that? I am looking at documentation and can't find how this can be done.
paullimapa
Look at this thread
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
Open your Template file, or blocks library file, or some file you'll never lose but always use for custom-to-you content.
Inside that DWG file you will create a custom-to-you named TABLESTYLE.
Now create a TABLE from that style.
Add a second TITLE row manually.
Drag and drop this custom table to your own custom ToolPalette (TP), or make a block of if from WBLOCK command and export out to a shared folder.
Your will no always drag-n-drop this from that custom TP, or INSERT that block when you need it (remember to explode it after insertion).
Done.
kevinlZL4WG
Thanks for the response. I am trying to do this programmatically. Do you know how that can be done?
paullimapa
Did you read my response to you in message 2?
Paul Li
IT Specialist
@The Office
Sea-Haven
Found a few things comparing 2 tables styles
normal table
TableStyleOverrides (RO) = NIL
HeaderSuppressed = 0
Modified 2 title rows
TableStyleOverrides (RO) = (2)
HeaderSuppressed = -1
I could not find a second override. Maybe some else can.
