How to change units of input/output parameter in Subassembly Composer
JaysonE
Message 1 of 1
JaysonE
I have created a custom curb subassembly with the subassembly composer. The problem is that the input dimensions are in "feet". And, it looks funny because the standard curbs subassemblies use inches.
Is there a way to have the parameters use "inches" and thereby show up in the Properties Palette the same way as the standard subassemblies?
I've read that the .pkt files are just .zip files and when I change the extension to zip and extract it. There is a file that is an .xml file.
Can I just insert an expression to specify the units there, save it and change the extension back to .pkt?
Any help on this would be appreciated.
Replies (0)
