How to change the color of a block?
I usually don`t have any issues changing the colour of a block but on this file, I don`t manage to change it. Does anyone got an idea how to change the red to black and green to black?
Is there a tutorial? Also, why it doesn`t not change if we select the objects and change the property color?
Many thanks,
Kent1Cooper
Assign the color "BYBLOCK" to all pieces within Blocks that you want to take on the color that is assigned to the Block insertion.
Kent Cooper, AIA
It doesn`t seem to work. Are you able to test it on the file I`ve included?
Many Thanks,
john.uhden
Here is an example of what @Kent1Cooper meant.
It changes every entity within a block definition to color ByBlock, which then allows a block insertion (reference) to have its color changed, independent of layer color, which is most prevalent by AutoCAD users.
(defun C:BB ( / *error* @reset |e |e0 |ent |etyp |done |bname |ans |flag)
   ;*         BB.LSP     by     John F. Uhden                                   *
   ;*                           2 Village Road                                  *
   ;*                           Sea Girt, NJ  08750                             *
   ;* * * * * * * * * * * *  Do not delete this heading!  * * * * * * * * * * * *
   ; Program redefines all entities in a block definition to color BYBLOCK.
   ; v2.1 (10-24-97) corrected (redraw) and (chr 7)
   ; v15.00 (04-07-00) for R15
   ; v16.0 (02-10-2020) revised as freeware for Challoner, using R16
   (gc)
   (prompt "\nBB v16.0 (c)1994-2020, John F. Uhden")
   (prompt "\nThis routine will redefine all entities in a block to color BYBLOCK.")
   (vl-doc-set '$cv_cmdname (getvar "cmdnames"))
   (defun *error* (error)
      (mapcar 'setvar vars vals)
      (vla-endundomark *doc*)
      (cond
        (not error)
        ((wcmatch (strcase error) "*CANCEL*,*QUIT*")
          (vl-exit-with-error "\r                                              ")
        (1 (vl-exit-with-error (strcat "\r*ERROR*: " error)))
      (princ)
   ;; Intitialze drawing and program variables:
   (setq *acad* (vlax-get-acad-object))
   (setq *doc* (vlax-get *acad* 'ActiveDocument))
   (vla-startundomark *doc*)
   (setq vars '("cmdecho" "highlight"))
   (setq vals (mapcar 'getvar vars))
   (mapcar 'setvar vars '(0 1))
   (command "_.expert" (getvar "expert")) ;; dummy command
   (if (setq |e0 (entsel "\nPick a block to redefine: "))
      (progn
         (setq |e0 (car |e0)
               |ent (entget |e0)
               |etyp (cdr (assoc 0 |ent))
               |flag (cdr (assoc 70 |ent))
         (redraw |e0 3)
         (if (and (= |etyp "INSERT")(= (logand |flag 4) 4))
            (setq |etyp "Xref")
         (if (= |etyp "INSERT")
            (progn
               (setq |bname (cdr (assoc 2 |ent))
                     |e (tblsearch "block" |bname)
                     |e (cdr (assoc -2 |e)) |done nil
               (prompt (strcat "\nBlock name is " |bname "."))
               (initget "Yes No")
               (setq |ans (getkword "\nAre you sure you want to redefine it?  Yes/<No>: "))
               (if (= |ans "Yes")
                  (progn
                     (while (not |done)
                        (setq |ent (entget |e))
                        (if (assoc 62 |ent)
                           (setq |ent (subst (cons 62 0)(assoc 62 |ent) |ent))
                           (setq |ent (append |ent (list (cons 62 0))))
                        (entmod |ent)(entupd |e)
                        (if (not (setq |e (entnext |e)))(setq |done 1))
                     (prompt "\nDisplay will be correct after next regen.\n")
            (prompt (strcat "\nEntity selected is a(n) " |etyp "."))
         (setq |e0 (redraw |e0 4))
   (*error* nil)
John F. Uhden
