How to change set up to default transparency to bylayer
syanchuck
syanchuck
I found that the default set up of transparency is 90, that mean when I draft the new object, I can't see it.
How I change it back?
Thank you in advance!
rkmcswain
Perhaps the CETRANSPARENCY system variable? Note that this is saved per drawing.
syanchuck
Then, should I set it Bylayer or 0?
rkmcswain
I posted the link to the documentation. That depends on how you want it to behave.
0
Fully opaque (not transparent)
-1 (ByLayer)
Transparency value determined by layer
