- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone!
I've worked hard on a .LSP script to automatically modify an exported AutoCAD DWG from Inventor. To make it simple, the modifications make the exported DWG complying to our client drawing standards (ie. border + texts on PaperSpace, the rest on ModelSpace).
For now everything works fine except one thing, all the non-Annotative leaders' Dim Scale Overall properties are 1 and I need to make them to a specific value (Inventor's Base View Scale when exporting everything to ModelSpace)
I just can't find a way to do this with a command.
I've already tried changing the DIMSACLE value, it's not working with dimensions that are already placed. I've also tried the _-CH _P command but it only allow's to change the General Properties, not the rest.
The code i'm planning to use is :
(setq UsrQA2 (getvar "QAFLAGS")) (setvar "QAFLAGS" 1) (command "???" "PARAM" (ssget "_X" '((0 . "LEADER"))) "" ) (setvar "QAFLAGS" UsrQA2) (princ)
Thanks for your help!
