Yes, I can provide more details.
I'm working on creating utility pole diagrams from given blocks. These blocks are pole frame assemblies (ex. cross-arms, transformers, primary and secondary attachments, downguys, arresters, etc.). These blocks follow engineering and construction standards. I'm currently manually adding and removing blocks (pole frame assemblies) to construct a pole diagram for construction.
An example of a frame assembly block would be a cross-arm and a transformer and a lightening arrester dimensioned accordingly.
For example, I need to create a pole that needs 2 cross-arms for each circuit, transformer, downguy and deadend attachments for neutral and secondary. This all comes in one block and I can just copy and paste it on a pole, and we're done. It gets more complicated and time consuming once you start to deal with more complicated pole frame assemblies where you have both distribution and transmission on one pole
For this reason, I'm looking for a tool that helps me generate a pole diagrams by choosing specific and multiple blocks(pole frame assemblies).
