- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How to shorten the Ref. Drawing Edit box and lengthen the Model code edit box.
I tried changing the width = but nothing changed.
Ref. drawing edit box and model code edit box
: row {
: boxed_column { label = "KHUNG TRAI";
: text { label = "REF. DRAWING";}
: edit_box { key = "REFDRAWING";}
: boxed_column {
: text { label = "MODEL CODE";}
: edit_box { key = "MODELCODE";}
.dcl
newform_dialog : dialog {
label = "XXX";
: row {
//KHUNG TREN---------------------------
: boxed_row { label = "KHUNG DUOI";
: row {
: column {
: text { label = "TITLE";}
: text { label = "SUB TITLE";}
: text { label = "DRAWING NO.";}
: text { label = "REVISION";}
: column {
: edit_box { key = "TITLEKD";}
: edit_box { key = "SUBTITLE";}
: row {
: edit_box { key = "DRAWINGNO";}
: button { label = "Get"; }
: edit_box { key = "REVISION";}
//KHUNG DUOI--------------------------
: boxed_row { label = "KHUNG TREN";
: row {
: column {
: text { label = "CTG.";}
: text { label = "REMARKS";}
: text { label = "PREP.";}
: text { label = "M.F.";}
: column {
: edit_box { key = "CTG";}
: edit_box { key = "TITLEKT";}
: edit_box { key = "REMARKS";}
: edit_box { key = "PREP";}
: edit_box { key = "MF";}
// O Reference drawing va o model code
: row {
: boxed_column {
//KHUNG TEN------------------------------------
: boxed_row { label = "KHUNG TEN";
: row {
: column {
: text { label = "APPROVED";}
: text { label = "REVIEWED";}
: text { label = "DATE";}
: column {
: edit_box { key = "APPROVED";}
: edit_box { key = "REVIEWED1";}
: edit_box { key = "DATE";}
: column {
: row {
: column {
: text { label = "PREPARED";}
: column {
: edit_box { key = "REVIEWED2";}
: edit_box { key = "PREPARED";}
: row {
: button { label = "Today";}
: button { label = "Assy";}
: button { label = "Part";}
: row {
ok_button;
cancel_button;
: button { label = "About me";}
