How make a transparent command?
Message 1 of 31
Does anyone know how I can make the following
function transparent: (osnap (cadr (grread nil 1)) "end,int"); function
provided by Michael Puckett
Below is my attempt, and it does not work.
Can anyone tell me why, or suggest something else?
Thanks, Steve
(vl-load-com)
(defun ada-2 ()
(vlax-add-cmd "jsa-a" 'ada-2 "jsa-a" 1 )
Replies (30)
Message 2 of 31
Don't define it using (vlax-add-command).
Just do this:
(defun C:JSA-A ()
(command (osnap (cadr (grread nil 1)) "QUI,END,INT"))
(princ)
> Thanks, Steve
> (vl-load-com)
> (defun ada-2 ()
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* [email protected] */
/* http://www.caddzone.com */
Message 3 of 31
Thanks, Tony. I'm trying to make the kind of
tranparent command that you can call from
the button menu, while a lisp routine is in progress.
I would appreciate any tips you could offer
on this.
Steve
Message 4 of 31
Tony's right, just prefix the function with c: and then call it via 'name,
e.g. line [enter] 'jsa-a [enter] ...
However, the way you defined your function, if no object is under the cursor
for a snap to be realized, the osnap function will return nil. Since that
might not be your intent I had it default to the point where the cursor was
if there is no object to snap to.
(defun c:jsa-a ( / p)
(command
(cond
( (osnap (setq p (cadr (grread nil 1))) "_endp,_int"))
( p )
(princ)
If It was desirable to have the routine return nil just skip my rambling.
__________________________________
Michael Puckett
[email protected]
> Not < an Autodesk hall monitor.
Imagination makes all things possible.
Copyright (c) 2000 Michael Puckett
All Rights Reserved
"Steve Adams" wrote in message
news:[email protected]...
Thanks, Steve
(vl-load-com)
(defun ada-2 ()
Message 5 of 31
Hmmm ... if you only wanted to return a point if a valid snap was found you
could always ...
(if (setq p (osnap (cadr (grread nil 1)) "_endp,_int"))
(command p)
(princ)
Anyway, have fun ... I've other fish to fry.
Michael Puckett
[email protected]
All Rights Reserved
"Michael Puckett" wrote in message
(command
(cond
( p )
(princ)
Michael Puckett
[email protected]
All Rights Reserved
Thanks, Steve
(vl-load-com)
(defun ada-2 ()
Message 6 of 31
<< Anyway, have fun ... I've other fish to fry. >>>
Wait a minute, Michael. You ain't goin' to no fish fry
'till we we make this function truly transparent (i.e. one that can
be called *during* another lisp command. We don't want to get
the "can't re-enter autolisp" message".)
Just kidding. You can go to the fish fry if you want.
Steve
Message 7 of 31
I should have credited Eric Schneider with that
portion of "grread" code. Sorry Eric.
Steve
Message 8 of 31
Steve,
maybe the best method is to jump up & down
& scream until Autodesk changes the A2K
button/aux menu behaviour to be the same as R14.
i.e the button/aux line
endpt,int \
does what you want in R14, but does not work in A2K
Regards Ian
Steve Adams wrote in message ...
>on this.
>Steve
Message 9 of 31
Ian,
I lost a lot (mainly SoftEngine) when I moved from
R12 to R15. Maybe I went " a release too far"....
Ian Bryant wrote:
> Steve,
> endpt,int \
> Regards Ian
> >on this.
> >Steve
Message 10 of 31
Maybe it's the the even number syndrome,
R10 good, R11 a dog, R12 good, R13 a real dog, R14 good
R15 ???
Regards Ian
Steve Adams wrote in message <[email protected]>...
>Ian,
>Ian Bryant wrote:
>> Steve,
>> endpt,int \
>> Regards Ian
>> >on this.
>> >Steve
Message 11 of 31
(if (zerop (rem (atoi (getvar "acadver")) 2)) "good" "blech")
_____________________________________
[email protected]
> Not < an AutoDESK classroom monitor
All Rights Reserved
Ian Bryant wrote in message ...
R15 ???
Regards Ian
>Ian,
>Ian Bryant wrote:
>> Steve,
>> endpt,int \
>> Regards Ian
>> >on this.
>> >Steve
Message 12 of 31
Or if you're a bit sniffer ...
(if (zerop (logand 1 (atoi (getvar "acadver")))) "good" "blech")
[email protected]
All Rights Reserved
Michael Puckett wrote in message ...
[email protected]
All Rights Reserved
R15 ???
Regards Ian
>Ian,
>Ian Bryant wrote:
>> Steve,
>> endpt,int \
>> Regards Ian
>> >on this.
>> >Steve
Message 13 of 31
Woof woof,
Regards Ian
>[email protected]
>All Rights Reserved
>[email protected]
>All Rights Reserved
>R15 ???
>Regards Ian
>>Ian,
>>Ian Bryant wrote:
>>> Steve,
>>> endpt,int \
>>> Regards Ian
>>> >on this.
>>> >Steve
Message 14 of 31
Hi Steve,
maybe you can use vla-sendCommand here:
(defun ada-2 ( / p activedoc cmd)
(if (setq p (osnap (cadr (grread nil 1)) "_end,_int"))
(progn
(setq activedoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq cmd (strcat (rtos (car p) 2 16) ","
(rtos (cadr p) 2 16) ","
(rtos (caddr p) 2 16) "\n"))
(vla-SendCommand activedoc cmd)
Stephan
Message 15 of 31
Thanks, Stephan, but I couldn't get it to work.
Did it work on your end?
-Steve
Message 16 of 31
Hi Steve,
yes, by adding the line
(vlax-add-cmd "jsa-a" 'ada-2 "jsa-a" 1)
it works for me as a transparent command
in AutoCAD 2000 SP 1 & NT 4 SP 6.
Works with AutoCAD commands and with
lisp i.e. (getpoint).
Please can you explain why it
does not work for you.
Stephan
Message 17 of 31
Stephan,
Thanks for reminding me to vlax-add-cmd.
Your program works great. This will save me a hundred
button pushes a day. I really appreciate it.
Thank you,
Steve
Stephan Koster wrote:
> Hi Steve,
> Stephan
Message 18 of 31
Stephan - I've been running into an interesting problem with (vlax-add-cmd).
Here's the Scenario:
1.) I define a Lisp routine with the following:
(vl-load-com)
;; Zoom Extents (Command: ZE)
(defun agc-ze ()
(vla-zoomextents (vlax-get-acad-object))
(princ)
(vlax-add-cmd "ZE" 'agc-ze "ZE" 1)
2.) I start AutoCAD and create a new drawing, Then try the ZE command. At
this point it works exactly as it's supposed to...
3.) I open a second drawing in the same AutoCAD session, Then try the
command in the second drawing - Still works good...
1.) I then switch back to the First drawing I created. Trying the ZE command
again in this drawing now returns an Error: "Visual LISP command document
mismatch: ZE"
Any ideas on what I'm doing wrong?? I'm about ready to give up on this!
Phillip Kenewell
CAD Systems Technician
Air Gage Company
[email protected]
Message 19 of 31
Hi Phillip,
yes, this is a bug in AutoCAD 2000.
I published a workaround in this group some months ago.
I use that every day and it seems to work without problems.
Good luck
Stephan
P.S.:
If you can't find the message from last year here it is:
> vlax-add-cmd fails in MDI mode
> This and more bugs can you find here: http://www.dotsoft.com/
> As a workaround you can use a docmanager-reactor which redefines
> the commands every time you change the active document
> (not fully tested, but it seems to work):
> ;;; by Stephan Koster 1999
> ;;; enables vlax-add-cmd in MDI
> ;;; Global functions: AddCommandsHelper AddCommandsInMDI
> ;;; Global variable: *AddCommandsList*
> ;;; Example: Add commands "Test1" and "Test2" (transparent):
> ;;; (AddCommandsInMDI '(("Test1" test)("Test2" c:test2 "Test2" 1)))
> ;;; The functions must be defined before the call to AddCommandsInMDI
> ;;; A new call to AddCommandsInMDI with the same command name but
> ;;; changed function redefines the command
> ;;; Returns: A list of the commands succesfully defined
> (defun AddCommandsHelper (CallingReactor CommandList / return ok)
> (foreach x *AddCommandsList*
> (if (and (member (type (eval (caddr x))) '(SUBR USUBR EXRXSUBR))
> (setq ok (apply 'vlax-add-cmd (cdr x))))
> (setq return (cons ok return))
> return
> (defun AddCommandsInMDI (lst / old)
> (foreach x lst
> (vlax-remove-cmd (car x))
> (if (setq old (assoc (strcase (car x)) *AddCommandsList*))
> (setq *AddCommandsList* (subst (cons (strcase (car x)) x) old *AddCommandsList*))
> (setq *AddCommandsList* (cons (cons (strcase (car x)) x) *AddCommandsList*))
> (if (not InitializeAddCommandsReactor)
> (setq InitializeAddCommandsReactor
> (vlr-docmanager-reactor "InitializeAddCommands"
> '((:vlr-documentBecameCurrent . AddCommandsHelper))
> (AddCommandsHelper NIL NIL)
Message 20 of 31
(DEFUN MP ()
(SETQ MP1 (GETPOINT "\nSelect first point for MID-PICK..."))
(setq mpt2 (GETPOINT "\nSelect SECOND point for MID-PICK..."))
(setq ang (angle mp1 mpt2))
(setq dist (distance mp1 mpt2))
(SETQ MP (polar mp1 ang ( * 0.5 dist)))
(vlax-add-cmd "mp" 'mp)
why won't this work transparently within another lisp routine?
Rodney
Tony Tanzillo wrote in message
> Just do this:
> (defun C:JSA-A ()
> (princ)
function
> > Thanks, Steve
> > (vl-load-com)
> > (defun ada-2 ()
