How does tblsearch and member actually work.
emilio24DRY
Message 1 of 23
emilio24DRY
I have the code below that works, but I am not completely sure why it works. For example, line 6, the tblsearch command returns what exactly (I have looked here, but it is not enough information for my understanding). Within the condition statement between lines 5 and 8 how is that telling the code that the layer exists.
I have the same question about the member command in line 64. What exactly is happening with the code? Again, I have checked that it wo...
Is there a more extensive description of how tblsearch and member work with all the arguments that can be passed through it?
Thanks!
(defun ECR:deleteLayer ( LAYER / )
;; CHECKS IF LAYER EXISTS BEFORE DELETING LAYER
	;; ADD TEXT TO ADD IF IT DOESN'T EXIST (CONDITION ELSE?)
	(cond
		((tblsearch "layer" LAYER)
			(command "-laydel" "name" LAYER "" "yes")
		);LAYER EXISTS
		(t
			(princ (strcat "\n-\n" LAYER " does not exist to be deleted\n-\n"))
		);ELSE
	);COND
(princ)
(defun ECR:setCurrentLayer ( LAYER / )
;; SET CURRENT LAYER
	;; ADD SOME ERROR CHECKING TO CHECK IF THE LAYER EXISTS
	(cond
			(command "-layer" "set" LAYER "")
		); LAYER EXISTS
		(t
			(command "-layer" "set" "1-DUMP" "")
			(princ (strcat "\n-\n" LAYER " does not exist to be set to current (setCurrentLayer). Layer ''1-DUMP'' Set to current\n-\n"))
		);ELSE
	);COND
(princ)
(defun ECR:thawLayer ( LAYER / )
	(cond
			(command "-layer" "THAW" LAYER "")
		);LAYER EXISTS
		(t
			(princ (strcat "\n-\n" LAYER " does not exist to be thawed (thawLayer).\n-\n"))
		);ELSE
	);cond
(princ)
(defun ECR:setTab ( TAB / )
;; CHANGE TABS AND DO ZOOM EXTENTS ON THAT TAB
	(cond
		((member TAB (layoutlist))
			(setvar "ctab" TAB)
			(command "zoom" "extents")
		);LAYOUT NAME EXISTS
		(t
			(princ (strcat "\n-\n" TAB " does not exist to be set (setTab).\n-\n"))
		);ELSE
	);COND
(princ)
(defun ECR:deleteTab ( TAB / )
;; DELETES TAB BUT FIRST CHECK IF THE TAB EXISTS BEFORE TRYING TO DELETE
	(cond
			(command "-layout" "delete" TAB)
		(t
			(princ (strcat "\n-\n" TAB " does not exist to be deleted (deleteTab).\n-\n"))
		);ELSE
	);COND
(princ)
(defun ECR:renameTab ( OLD_TAB NEW_TAB / )
;; RENAME TAB BUT FIRST CHECK IF THE TAB EXISTS BEFORE TRYING TO RENAME
	(cond
		((member OLD_TAB (layoutlist))
			(command "-layout" "Rename" OLD_TAB NEW_TAB)
		(t
			(princ (strcat "\n-\n" OLD_TAB " does not exist to be renamed (renameTab).\n-\n"))
		);ELSE
	);COND
(princ)
Replies (22)
Message 2 of 23
paullimapa
Message 3 of 23
Kent1Cooper
The AutoLisp Reference entry for (member) is pretty clear if you read both the description at the top and the Return Values entry further down.  It returns the rest of the list starting with the item searched for, or nil if it's not in there.
For (tblsearch) it's a little less clear, not describing except by illustration what the "entry" is that it returns.  There are more properties of a Layer that it could include, but doesn't -- it's only "highlights," and you need (entget (tblobjname "layer" ...)) to get the more complete list.  But in the case of your code example, because it never actually uses any of the returned information, all you really need to know is that if there is no Layer by the name it's looking for, it returns nil.
Kent Cooper, AIA
Message 4 of 23
dbroad
For tblsearch, see:
AutoCAD 2023 Help | tblsearch (AutoLISP) | Autodesk
https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-2AEB84A6-E3D0-4DD9-A29C-54D4099ED92...
Returns basic information about a table entry as an association list. For the cond function in your example, any non-nil return value means that the layer exists.
Ex:
(tblsearch "layer" "0")
((0 . "LAYER") (2 . "0") (70 . 0) (62 . 7) (6 . "CONTINUOUS"))
(entget(tblobjname "layer" "0"))
((-1 . <Entity name: xxx-xxxxxxxx>) (0 . "LAYER") (5 . "7") (102 . "{ACAD_XDICTIONARY") (360 . <Entity name: xxx-xxxxxxxx>) (102 . "}") (330 . <Entity name: 2408272e1d0>) (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "0") (70 . 0) (62 . 7) (6 . "CONTINUOUS") (290 . 1) (370 . -3) (390 . <Entity name: 240827310a0>) (347 . <Entity name: 240827310d0>) (348 . <Entity name: 0>))
This wouldn't be helpful in your program but in other more advanced programs, it would give access to manipulating more properties the layer.
Information on other symbol tables can be found here:
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-7B91F774-B0CD-4F5B-9FFA-1130443E659B
For member, see:
AutoCAD 2023 Help | member (AutoLISP) | Autodesk
https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-A2B08751-D966-44F5-9B02-1AAC4DA6AF5...
Architect, Registered NC, VA, SC, & GA.
Message 5 of 23
emilio24DRY
So essentially, tblsearch and member return a value if it exists. How does line 6 actually work. Why don't you have to put for example:
-tblsearch equals a certain value or does not equal nil.
-Why does putting (tblsearch...) work without either equal to (eq) or does not equal (<>?) nil-or some other comparison statement to compare what you expect vs what comes out of tblsearch or member?
Message 6 of 23
paullimapa
There's nothing like trying the code yourself.
At the AutoCAD command prompt just enter the code and you'll see the response
For example if you do a tblsearch for layer "0" what would the response be:
Since every valid drawing must have a layer "0" you'll see that the command prompt returns:
Now try a layer name that doesn't exist like "12345"
(tblsearch "layer" "12345")
The command prompt would return nil because that layer does not exist. There's no need to do any other kind of comparison evaluation.
Likewise with member....just create a list by entering the following at the command prompt:
(setq test (list "A" "B" "D" "F"))
AutoCAD returns:
("A" "B" "D" "F")
Now use the member function to see if a matching item exists by entering the following at the command prompt:
(member "B" test)
Because that item "B" is available in the list AutoCAD returns all items after starting at the location the item is found:
("B" "D" "F")
But if you enter an item that does not exists with the member function like:
(member "C" test)
Since the item "C" is not in the list AutoCAD returns nil again without a need to do any further comparison tests
Paul Li
IT Specialist
@The Office
Message 7 of 23
Kent1Cooper
One thing to keep in mind:
In an (if) function, or at the beginning of a condition within a (cond) function, there's a test expression, and the (if) or (cond) is looking at only two possibilities for what is returned by that expression.  One possibility is nil, in which case the (if) function will perform its 'else' expression, or the (cond) function will move on to the next possible condition to check for [if there is one].  The other possibility is anything at all other than nil.  It doesn't matter whether it's a list [like what is returned by (tblsearch), a number, a text string, an entity name, a variable name if that contains anything other than nil, a mathematical function that returns a number, etc., etc.  If the return is any of the numerous non-nil possibilities, it will pass the test, and the (if) function will perform its 'then' expression, or the (cond) function will perform the remaining stuff spelled out within that condition [or if none, will just pass through the return of the test expression, which itself doesn't need to be a test, but can just be a text string or number or whatever].  So in situations like yours, there's no comparison to be made or equality to check for -- there's nothing needed beyond the simple nil-vs-anything-else check.
Kent Cooper, AIA
Message 8 of 23
emilio24DRY
@Kent1Cooper So if I am undertanding correctly, in my case, the first condition or if statement would be anything other than nil. If it is nil the else statement will catch anything else. Since my case is just checking that the layer exists, it is super simple.
	(cond
		);ANYTHING OTHER THAN NIL
		(t
		);IN MY CASE, THIS WOULD BE NIL
	);COND
(princ)
Message 9 of 23
Kent1Cooper
And if there's only one condition to check for, it can be even simpler:
  (if (tblsearch "layer" LAYER)
    (command "-laydel" "name" LAYER "" "yes"); 'then'
    (princ (strcat "\n-\n" LAYER " does not exist to be deleted\n-\n")); 'else'
  ); if
  (princ)
The (cond) function can be used for this, but is really built for situations with multiple possible conditions -- try the first one, and if its test passes do what it says, but if it fails go on to try the next one, etc., stopping at whichever condition's test expression passes first.
Kent Cooper, AIA
Message 10 of 23
paullimapa
FYI if there are objects on that layer the layer will not be deleted
Paul Li
IT Specialist
@The Office
Message 11 of 23
emilio24DRY
@paullimapa It pushes through those objects and deletes them-I tested it. It does put up a warning, but it does delete the layer and all the objects on those layers. In my case this is how I want it to work.
Message 12 of 23
Kent1Cooper
LAYDEL will delete it [including any objects on it] -- what you can't do to it is to PURGE it.  If it's the current Layer, it can't be deleted with LAYDEL, so it might be worth checking for that.
(defun ECR:deleteLayer (LAYER / ldata)
  (if
    (and
      (setq ldata (tblsearch "layer" LAYER)) ; it exists
      (/= (getvar 'clayer) LAYER) ; but it's not current
      (= (logand 4 (cdr (assoc 70 ldata))) 0) ; and not locked
    ); and
    (princ ; 'else'
      (strcat
        "\n-\n" LAYER " does not exist to be deleted, or is "
        "locked or is the current Layer and cannot be deleted."
        "\n-\n"
      ); strcat
    ); princ
  ); if
  (princ)
Or, if you really want to be rid of it even if it's current and/or locked, the 'else' could be to set Layer 0 current and then unlock and delete the one in question.
EDITED for the locked-Layer issue.
Kent Cooper, AIA
Message 13 of 23
paullimapa
that's true as long as the current layer is not the layer you want to delete.
Paul Li
IT Specialist
@The Office
Message 14 of 23
paullimapa
also won't work if the layer is locked.
Paul Li
IT Specialist
@The Office
Message 15 of 23
Kent1Cooper
Ah, yes....  I've Edited my previous Reply to account for that, too.
Kent Cooper, AIA
Message 16 of 23
paullimapa
So an interesting challenge would be to come up with code to check if the layer attempting to be deleted is current. If it is then set the current layer to another like as @Kent1Cooper stated layer 0. But you'll also have to check to make sure whatever layer you want to set current is also Thawed and not Frozen. A Frozen layer cannot be set current...happy coding...
Paul Li
IT Specialist
@The Office
Message 17 of 23
dbroad
@emilio24DRY
Re line 6:  look up how COND works. Each argument is tested. If that argument’s first element evaluates to nil, it skips evaluating the rest of that argument. Cond is like if but allows more than two choices. It’s one of the most effective branches in LISP.
Message 18 of 23
dbroad
@paullimapa
Have you used laydel?
Message 19 of 23
paullimapa
Yes I used it but I happened to have the layer I wanted to delete set current so that’s what prevented it from deleting and not that there are objects contained in the layer
Paul Li
IT Specialist
@The Office
Message 20 of 23
dbroad
My solution was to (...(setvar "clayer" "0")(command "laydel")...)  I never need to worry about being on a layer I want to delete. The lock icon shows those layers which are locked and I can live with unlocking those manually.
