How do I make my lisp so that it doesn't stop working when I click nothing
mkataQU96G
Message 1 of 13
mkataQU96G
I've been trying to add 3 things to my code
1. When the user clicks nothing, the code continues to run and doesn't increment
2. When the user clicks a something that isn't the correct block, it notifies the user to select the correct block
3. The only valid selection is either block "EQP_LBD-CMB" or "Trunk Cable", when the user selects either block it runs and increments.
I've tried a variety of things that I've found on the forums, but none seem to work. Here is my base code:
(defun C:EINC (/ *PCS* *block* *EQP* *EQP_Num*)
(vl-load-com)
(setq *PCS* (getstring "\nInput PCS Number: "))
(setq *EQP* (getint "\nInput Equipment Starting Number: "))
(while
(setq *block* (car (entsel "\nSelect Block: ")))
(setpropertyvalue *block* "PCS_NUM" *PCS*)
(setq *EQP_Num* (itoa *EQP*))
(setpropertyvalue *block* "EQP_NUM" *EQP_Num*)
(setq *EQP* (+ *EQP* 1))
(princ)
Replies (12)
Message 2 of 13
ВeekeeCZ
You need to check the ERRNO sysvar.
See Lee's example here
https://www.lee-mac.com/selectif.html
BTW, The common formatting style is to use asterisks *variable* only for global variables. As you have all your variables localized...
...which is a good and recommended practice, then you should not use asterisks. Use just plain names...
PCS block EQP EQP_Num
Message 3 of 13
mkataQU96G
Understood, thanks! I'll check out the selectif lisp you recommended
Message 4 of 13
Moshe-A
@mkataQU96G  hi,
Check my version - untested 😀
Moshe
(vl-load-com)
(defun C:EINC (/ *PCS* *block* *EQP* *EQP_Num* pick elist)
 (if (and
  (while (and
	  (setq pick (entsel "\nSelect Block: "))				; pick object
	  (not (member (getvar "errno") '(7 52)))				; yes, object is selected (errno = 7 means empty pick, errno = 52 means ESC or empy enter)
	  (setq elist (entget (setq *block* (car pick))))			; get object database list
	  (eq (cdr (assoc '0 elist)) "INSERT")					; is it a block?
	  (wcmatch (cdr (assoc '2 elist)) "EQP_LBD-CMB,Trunk Cable")	; is it "EQP_LBD-CMB,Trunk Cable"?
  ); while
 ); if
 (princ)
Message 5 of 13
mkataQU96G
Running it, it exits the command no matter what i click on after i input the equpment and pcs numbers
Message 6 of 13
Moshe-A
@mkataQU96G ,
Sorry, here is fix.
i notice that (setpropertyvalue) return error if you pass the propertyname as uppercase string so i switched to lowercase.
as you get more experience you'll learn a more safe method to modify block attributes.
Moshe
(vl-load-com)
 (setvar "errno" 0)
 (if (and
      (setq *PCS* (getint "\nInput PCS Number: "))
  (while (and
   (setpropertyvalue *block* "pcs_num" (itoa *PCS*))
   (setpropertyvalue *block* "eqp_num" (itoa *EQP*))
   (setvar "errno" 0)
  ); while
 ); if
 (princ)
Message 7 of 13
ec-cad
This model gets you a little further. But, 'and  condition excludes 'Text' or other items like a Line,
if that's selected. So, maybe a 'Filter and SSGET might do it ?
ECCAD
(vl-load-com)
 (setq bn "")
 (setvar "errno" 0)
 (if (and
     );and
  (while (and
          (setq bn (strcase (cdr (assoc '2 elist))))            ; get block name
          (setq etype (cdr (assoc 0 elist)))                    ; check entity type of pick
         ); and
         (if pick
          (progn
            (if (/= etype "INSERT")
              (alert "Item Selected is not a Block:")
            ); if
            (if (and (/= bn "TRUNK CABLE")
                     (/= bn "EQP_LBD-CMB")
                ); and
                (alert "Please select the correct Block:")
            ); if
           (if (or (= bn "TRUNK CABLE")(= bn "EQP_LBD-CMB"))
            (progn
            ); progn
           ); if
          ); progn
         ); if
    (setvar "errno" 0); reset error
  ); while
 ); if
 (princ)
Message 8 of 13
paullimapa
I'm assuming you want to only select Blocks (named either "EQP_LBD-CMB,Trunk Cable") containing Attributes (Tag names: "PCS_NUM" & "EQP_NUM")
What I would do is use the ssget function that (1) mimics the entsel function & (2) supports filters "_+.:E:S:L" so you can only select a Block on Layer that's not locked with Attributes'((0 . "INSERT") (66 . 1)):
(defun C:EINC (/ *PCS* *block* *EQP* *EQP_Num* nam nam-match)
  (if (and
      (setq nam-match "EQP_LBD-CMB,Trunk Cable")
  (while (not *block*)
   (princ"\nSelect Block: ")
   (setq *block* (ssget "_+.:E:S:L"'((0 . "INSERT") (66 . 1)))) ; select only blocks with attributes on unlocked layers
   (if *block*
    (progn
     (setq *block* (ssname *block* 0) ; get entity from selection
           nam (getpropertyvalue *block* "BlockTableRecord/Name") ; get block name
     (if(wcmatch nam nam-match) ; chk for block name match
       (progn ; then
       ) ; progn
       (progn ; else
        (princ(strcat"\nBlock Selected is Named " nam " Does NOT Match..."))
        (setq *block* nil) ; reset selection
     ) ; if
    ) ; progn
   ) ; if
  ) ; while
 ) ; if
 (princ)
Paul Li
IT Specialist
@The Office
Message 9 of 13
mkataQU96G
This works exactly how I need it to! I had to add a space between princ and "\nSelect Block: ") in order for it to fully function, but aside from that, it's perfect! thanks!
Message 10 of 13
mkataQU96G
Thank you all for the support and suggestions! I definitely learned a lot!
Message 11 of 13
paullimapa
Glad that worked out for you…cheers!!!
Paul Li
IT Specialist
@The Office
Message 12 of 13
ec-cad
I tried the last example, and it only does (1) block. Seems to me that you would want to pick several in order
to make use of the 'incrementing' of the *EQP* variable (number), so I suggest something like this,
IF you want to do more than just 1 block..
 (setq FLAG 0); Set Exit Flag 0
  (if (and
     ); and
  (while (= FLAG 0); While FLAG is still 0
   (princ "\nSelect Block: ")
   (if (not *block*); must have not picked anything..so set Exit Flag 1
    (setq FLAG 1)
   ); if
   (if *block*
    (progn
     (if (wcmatch nam nam-match) ; chk for block name match
       (progn ; then
       ) ; progn
       (progn ; else
        (princ (strcat"\nBlock Selected is Named " nam " Does NOT Match..."))
        (setq FLAG 1) ; reset exit Flag
       ); progn
     ) ; if
    ) ; progn
   ) ; if
  ) ; while
 ) ; if
 (princ)
ECCAD
Message 13 of 13
Sea-Haven
Why not add the block names to the ssget ?
(setq *block* (ssget "_+.:E:S:L"'((0 . "INSERT")(2 . ""EQP_LBD-CMB,Trunk Cable"")(66 . 1))))
