Error boundary Xline
martin_leiter
Message 1 of 24
martin_leiter
Please help.
I have the following Lisp:
(defun c:umgrxlinien (/ AWS)
(setvar "HPISLANDDETECTIONMODE" 0)
(setvar "HPISLANDDETECTION" 2)
(if(setq AWS(ssget "X"
'( (-4 . "<OR")
(0 . "XLINE")
(0 . "Ray")
(-4 . "OR>")
(command-s "-umgrenzung" "o" "U" "N" AWS "" "" "_non" Pause))
(princ)
The error only occurs in Acad 2025. In Acad 2024 everything works normally and a boundary is created within the Xlines.
In 2025, however, if a line crosses the boundary of the Xlines, only the part up to this line is recognized as a boundary.
I have tried many things but nothing works.
Can someone help?
Martin
Replies (23)
Message 2 of 24
Kent1Cooper
Spell out for us what those option letters stand for in the apparently German version.
Kent Cooper, AIA
Message 3 of 24
Moshe-A
@martin_leiter hi,
if i understand you it is about BHATCH inside XLINES or RAYS
maybe the last 2 arguments are redundant? cause we assume after selecting objects we are done.
btw, when using (command-s) function,  you need not to be worry about the command arguments cause it will pause for your inputs until command is done, only then the execution will move to the next expression\call.
Moshe
Message 4 of 24
martin_leiter
Hello Moshe-A,
Thanks for your help.
Unfortunately, that doesn't work either.
The selection is recognized and also specified in the command line. But it seems as if the selection is not recognized during the point analysis.
The only strange thing is that when I execute the integrated command via the Draw-Boundary tab, the Xlines are recognized and the boundary is created correctly.
As I said, the problem has only existed since acad 2025.
Martin
Message 5 of 24
Moshe-A
@martin_leiter ,
check this one 😀
you need to take care of hatch scale.
Moshe
(defun c:MyBHatch (/ AWS)
 (if (setq AWS (ssget "X" '((-4 . "<OR") (0 . "XLINE") (0 . "Ray") (-4 . "OR>"))))
  ; (command-s "-umgrenzung" "o" "U" "N" AWS "" "" "_non" Pause)\
  (command-s "._bhatch"
             "_A"	; Advanced
             "_B"	; Boundary set
             "_N"       ; New
             "_si"      ; single selection
             AWS        ; have my selection
             ""  	; continue
             pause	; pick analysis point
             "")	; finish
 (princ)
Message 6 of 24
martin_leiter
Hello Moshe-A
Thanks for the help.
Yes, with the hatching it works as you wrote.
But I just want to create a border without hatching.
That doesn't work with acad 2025.
I only set the system variables at the beginning because I thought they would be involved.
But that doesn't seem to be the case.
Best wishes
Martin
Message 7 of 24
Moshe-A
@martin_leiter ,
that's very easy to implement 😀
(defun c:MyBPoly (/ aws)
 ;(setvar "HPISLANDDETECTIONMODE" 0)
 ;(setvar "HPISLANDDETECTION" 2)
 (if (setq aws (ssget "X" '((-4 . "<OR") (0 . "XLINE") (0 . "Ray") (-4 . "OR>"))))
  ; (command-s "._bhatch"
  (command-s "._boundary"
             "_A"	; Advanced
             "_B"	; Boundary set
             "_N"       ; New
             aws        ; have my selection
             ""  	; continue
             "")	; finish
 (princ)
Message 8 of 24
martin_leiter
Hello Moshe-A
I ran your Lisp.
Unfortunately the border is not recognized correctly.
See picture
Kind regards
Martin
Message 9 of 24
martin_leiter
One possibility might be to use the Lisp with the hatching
but first activate the setting for the hatching "Create border".
Then create the hatching with the border and then delete the hatching without the border.
You would then also have to deactivate the setting for the hatching options "Create border".
This would give you the border.
Would that be possible?
What do you think?
Best wishes
Martin
Message 10 of 24
Moshe-A
@martin_leiter
In the (ssget) call you filter out all objects except for xlines and rays. now you say i also want a polyline 🤔
OK i added polyline.
works?
 (if (setq aws (ssget "X" '((-4 . "<OR") (0 . "XLINE") (0 . "Ray") (0 . "LWPOLYLINE") (-4 . "OR>"))))
             "_A"	; Advanced
             "_B"	; Boundary set
             "_N"       ; New
             ""  	; continue
             "")	; finish
 (princ)
Message 11 of 24
martin_leiter
Hello Moshe-A
Have you seen my picture?
Unfortunately, this doesn't work in Autocad 2025.
The preselected boundaries (Xlines) are ignored when using the boundary command.
This is the case with Lisp and it is also the case when I enter the boundary command in the command line.
It only works with the Acad command if you activate it via the "Draw" "Boundary" tab.
Please excuse me if I cause such trouble.
Martin
Message 12 of 24
Moshe-A
@martin_leiter ,
Hello Moshe-A
Martin
did i see your picture? well, how did i know to add the polyline to the filter???
take a look at my picture:
AutoCAD R2025
the red lines are xlines
the green lines are rays
the cyan box is polyline
the white is boundary generated by (c:MyBPoly)  function
if your AutoCAD doesn't do that then something wrong with your AutoCAD version.
check if there is an update or enter your autodesk account and check for update there.
or install an English version, but not on the same computer.
Moshe
Message 13 of 24
Kent1Cooper
.... the border is not recognized correctly.  See picture ....
I think there's some confusion.  Am I right that what is "not recognized correctly" about the above is that with the blue Xlines selected, you do not want the purplish rectangle to be considered, but only the Xlines, and you want this green result?
[Pardon my freehand.]  I think your description in Message 1 is consistent with this being the desired result [a Line crossing there, a rectangle corner infringing here].  That would mean that Polylines should not be added to the selection filtering.
Do I understand correctly?
Kent Cooper, AIA
Message 14 of 24
Kent1Cooper
.... if a line  [red below]  crosses the boundary of the Xlines  [blue] , only the part up to this line  [the green result]  is recognized as a boundary. ....
To further clarify, as I understand that description:
But if the blue Xlines [or Rays] are selected as what should define the boundary, and a pick is made inside the larger area in the middle, what you want is not the green area only up to the red Line, but the white result on the right, ignoring the red Line and reading only the selected blue Xlines as bounding objects.  Is that the idea?
Kent Cooper, AIA
Message 15 of 24
komondormrex
if you are going to pick a point, why then you do not select all like this
;;;(setvar "HPISLANDDETECTIONMODE" 0)
;;;(setvar "HPISLANDDETECTION" 2)
;;;'( (-4 . "<OR")
;;;(0 . "XLINE")
;;;(0 . "Ray")
;;;(-4 . "OR>")
(command-s "_.-boundary" "_a" "_i" "_y" "_b" "_n" AWS "" "" "_non" Pause ""))
(princ)
 or just simply pick the inside point
	(command-s "_.-boundary" "_a" "_i" "_y" "" "_non" Pause "")
	(princ)
Message 16 of 24
martin_leiter
Hello Kent Cooper
yes, exactly!
The white object should be the result.
The problem is Autocad 2025. As of this version, my Lisp no longer works.
It worked without problems until Acad 2025.
It would be important if someone could test it in Acad 2025.
Best regards
Martin
Message 17 of 24
hmsilva
Can someone help?
Martin
@martin_leiter unfortunately this is not a solution to the behavior of the -boundary command in AutoCAD 2025, I did test and the behavior is not the same as previous versions...
 This is just a slow workaround…
(defun c:demo (/ pt ss)
    (if	(and (setq ss (ssget "_X" '((0 . "XLINE,RAY"))))
	     (setq pt (getpoint "\nPick internal point: "))
	(progn
	    (command "._IsolateObjects" ss "")
	    (bpoly pt)
	    (command "._UnIsolateObjects")
    (princ)
Hope this helps,
Henrique
Message 18 of 24
martin_leiter
Thanks Henrique
yes, I thought of that too.
This is working well for now
Maybe someone else has an idea
Martin
Message 19 of 24
ВeekeeCZ
Have you tried this predecessor without n or with the argument of 1 or 2?
(initcommandversion n)
Message 20 of 24
hmsilva
Thanks Henrique
Martin
@martin_leiter another workaround, faster than the previous one…
(defun c:demo (/ new old pt ss)
	(progn
	    (setq old (entlast))
	    (command "._-bhatch" "_A" "_B" "_N" ss "" "_A" "_N" "R" "_Y" "" pt "")
	    (setq new (entlast))
	    (if	(and (not (eq old new))
		     (= (cdr (assoc 0 (entget new))) "HATCH")
		(entdel new)
    (princ)
Hope this helps,
Henrique
