How do I import multiple DXF files into one drawing at the same time.
Good day, all.
I looked around and couldn't find exactly what I am looking for.. I do a lot of manual nesting for the company that I work for. We do not use any auto nesting software. I am looking for a way to open all my DXF files in one DWG at the same time, so I can nest them all. As is, I am currently opening each file individually and copying and then pasting it into my "master drawing" where I create a good nest for our cnc plasma table. Any suggestions would greatly be appreciated.
Seth
pendean
Community Legend
Community Legend
How would you want the program to guess at placement of many files dropping in all at once?
Sea-Haven
You can insert a dxf, I would use (getvar 'extmax) (getvar 'extmin) this will give the corners of the current dwg, get the right X the bottom Y as the insertion point.
You will need a script of some form that reads the dxf file names then runs a lisp to actually insert.
; save as insertdxf.lsp
(defun insdxf (fname / top bot pt) (setq top (getvar 'extmax)) (setq bot (getvar 'extmin)) (setq pt (list (car top)(cadr bot)) (command "-insert" fname pt 1 1 0) )
script
(load "insertdxf")
(insdxf "c:\\myfolder 1\\myjobs\\dwg1.dxf") (insdxf "c:\\myfolder 1\\myjobs\\dwg2.dxf") (insdxf "c:\\myfolder 1\\myjobs\\dwg3.dxf")
Use say Lee-mac srciptwriter to create the script.
maratovich
Use it : AutoViewport
https://youtu.be/rMXZ6hb7DTM
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
