How do I get command dialog box through lisp.
Timothy_BrooksU4G6R
Timothy_BrooksU4G6R
Autocad has a few commands that automatically calls a dialog box like; plot, style and etc. However, when I call one of these commands via lisp (command “plot”) I don’t get dialog version, I get the text version like: -plot.
So I wrote lisp routine to setup plot setting, at the end of lisp routine I want to call up the normal plot dialog box, but I don’t know how to call that.
Any advice?
ВeekeeCZ
Use (initdia) before (command "plot")
Timothy_BrooksU4G6R
surprisingly simple, thanks
paullimapa
and here's another way:
(vla-sendcommand(vla-get-activedocument(vlax-get-acad-object))"_.Plot\r")
Paul Li
IT Specialist
@The Office
Sea-Haven
Do you really need to call Plot dialogue or just use a plot lisp ?
    (COMMAND "-PLOT"  "Y"  "" "Plot To PDF"
	       "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C"
	       "y" "Acad.ctb" "Y"	"n" "n" "n" pdfName "N" "y"
You can make your own small dcl to set say some relevant values.
