Assigning an action to a dynamic block parameter in the block editor
tymon067
tymon067
Hello!
I have dozens of block references to which I would like to add a dynamic parameter.
I handled adding the paramter:
(command "_-bedit" (cdr (assoc 2 (entget blk))))
(command "_bparameter" "point" "label" "Name" '(0 0 0) '(0 1 0) 1)
(setq par (entlast))
But I have a problem with assigning an action to this parameter, specifically with paramter selection.
I tried to do this in the following ways:
Command: (command "_.BACTION" "move" par)
_.BACTION
Select parameter: move
*Invalid selection*
Expects a single object.
; error: Function cancelled
or:
Command: (command "_BActionTool" "move" par)
_BActionTool
Enter action type [Array/Lookup/Flip/Move/Rotate/Scale/sTretch/Polar stretch]: move
Select parameter:
Select parameter: nil
or even:
Command: BACTION
Select parameter: !par
<Entity name: 21c039a9f50>
and constantly prompts: Select parameter
I also try with ssget instead of entlast, but wothout success.
Have a good day!
ВeekeeCZ
You know it's coords, use them.
tymon067
Thanks @ВeekeeCZ
But honestly, I don't know what to do with this information 🙂
From my point of view, the problem is not in the selection of parameter itself, the problem is more how to process it through "BActionTool" command.
ВeekeeCZ
Ok, it seems that BACTION requires to have some point. Any point.
So for your simple example - you know the coords, the parameter is, as the last object, on top, then a point is enough...
(command "baction" "0,0" "move"...)
But as BACTION is stubborn but stupid, you can supply him with ename in the "entsel" pair, and use any point.
(command "baction" (list par '(100000 10000)) "move" ...)
PS
Give it some meaningful name, this is confusing.
tymon067
Thank you for the perfect explanation!
Have a great day 🙂
