How can I put a block on a tool palette with code?
matthew_neesley
matthew_neesley
Hello to all:
I wanted to bump this topic to current-viewing again:
https://forums.autodesk.com/t5/net/how-to-create-a-tool-in-toolpalette-that-can-import-and-insert-a/...
I really, really need the ability to build tool palettes full of blocks by coding.  Yes, I need to do it this way, I have to constantly re-make close to 50 tool palettes every 3 weeks or so.  It is an extremely arduous task, and very soon, I will have to make close to ONE HUNDRED tool palettes.  No, we can't make them "networked" either, they have to be distributed externally to our customers who use our blocks.
One of the major driving forces behind this request is we need the ability to mix-and-match blocks from various releases, such as Rev 11-1 of Block #50 at the same time as Rev 10-3 of Block #50 and so on.  So the name of the block in the resource dwg may not change...execept for the rev number in that block name.  Overall, this may not sound like a good idea, but it is the setup I have to operate in.  Reasoning/rationale for it is too much to elaborate on in this initial post, trust me.
I have done an absolute TON of searching over the last week.  I keep finding "put commands" or "put buttons" on a tool palette with code.  I MUST have the coding ability to put a BLOCK on a tool palette, and then set Tool Properties with code also.
I cannot build an XML/write an atc file from scratch to make a tool palette like that, I have tried that, and the code is waaaaay too much to try and decipher/reverse engineer; that is NOT an option.
Is what I want possible within the API with any officially defined Methods?  I myself am not an experience coder, but I have several coworkers who are, so if you have applicable fragements of knowledge, I'm all ears. This would change my whole world unbelievably 😁
Sea-Haven
I wrote make MNU files similar task. I don't use tool palettes rather mnu as I said but start here. Good and bad news appears they are XML files so if you can work out the patterns could write a atc file. I would add a new tab then find it.
  • The AutoCAD Tool Palettes are .atc files. Their content is in XML format, which can be read in a Text-editor program.
matthew_neesley
Thanks for your response, But I don't think I could make that work in a timely fashion.  This has been suggested to me before, so yes I have cracked open one of the XML files before, but that is way too much to try and decipher at this point.
