How to create a tool in toolpalette that can import and insert a block?
ShricharanaB
ShricharanaB
I'm trying to learn the "Autodesk.AutoCAD.Windows.ToolPalette" namespace for a project and I'm going through the sample project "SimpleToolPaletteExample.csproj". ( for AutoCAD 2020)
As far as I can understand,
tool.CreateFlyoutTool() is used for a flyout tool,
tool.CreateCommandTool() is for command tool and so on.
How would I create a tool that imports and inserts a block ? I mean the same to created by dragging and dropping a block onto the Toolpallete in an open AutoCAD drawing?
The final goal:
I have folders in which I have drawings. These drawings have various blocks. The folder structure and block names etc. may change over time.
So, I want to create a command that iterates through all these folders, drawings and block, creates an index for each block, then creates a new tool palettes for each block without me having to drag and drop each and every block into the tool palette. So that the user can just click on these tools to insert the block without having to manually import it from the source block.
Here is the code that exists in the sample project that comes with ObjectARX download for reference.
//  Copyright 2019 Autodesk, Inc.  All rights reserved.
//  Use of this software is subject to the terms of the Autodesk license
//  agreement provided at the time of installation or download, or which
//  otherwise accompanies this software in either electronic or hard copy form.
using System;
using System.Windows;
using System.Windows.Forms;
using System.Drawing;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Windows.ToolPalette;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
//[assembly: ExtensionApplication(null)]
//[assembly: CommandClass(typeof(SimpleToolPaletteExample.Command))]
namespace SimpleToolPaletteExample
	/// <summary>
	/// Summary description for Class1.
	/// </summary>
	[Guid("ADB8A9F8-E340-429e-BC10-1FE38D69A2D3")]
	[Tool("MySimpleTool", "IDB_TOOL1")]
	[FlyoutEntry(2)]
	[ClassInterface(ClassInterfaceType.AutoDual)]
	public class SimpleTool : CustomToolBase
		public SimpleTool()
		[ComVisible(true)]
		[DispId(1)]
		public string CmdName
			get { return m_cmdName;}
			set { m_cmdName = value;}
		[DispId(2)]
		public string Flyout
			get { return m_flyout;}
			set { m_flyout = value;}
		[DispId(3)]
		public double StartX
			get { return m_startX;}
			set { m_startX = value;}
		[DispId(4)]
		public double StartY
			get { return m_startY;}
			set { m_startY = value;}
		[DispId(5)]
		public double StartZ
			get { return m_startZ;}
			set { m_startZ = value;}
		[DispId(6)]
		public double EndX
			get { return m_endX;}
			set { m_endX = value;}
		[DispId(7)]
		public double EndY
			get { return m_endY;}
			set { m_endY = value;}
		[DispId(8)]
		public double EndZ
			get { return m_endZ;}
			set { m_endZ = value;}
		/// <summary>
		/// ITool override
		/// </summary>
		public override void New()
			m_startX = 2.0;
			m_startY = 2.0;
			m_startZ = 0.0;
			m_endX = 8.0;
			m_endY = 8.0;
			m_endZ = 0.0;
			m_cmdName = "_LINE";
		const int MF_STRING = 0;
		const int MAX_MENU_ENTRIES = 3;
		static uint[] m_nMenuIds = new uint[] {0,0,0 };
		///IAcadToolContextMenu
		public override UInt32 Customize(Int32 nContextFlag, UInt32 hMenu,
			UInt32 idCmdFirst, UInt32 idCmdLast,
			ref Guid pPaletteId)
			uint maxMenu = (idCmdLast - idCmdFirst) < MAX_MENU_ENTRIES ? (idCmdLast - idCmdFirst) : MAX_MENU_ENTRIES;
			CatalogItem item = ToolPaletteManager.Manager.Catalogs.Find(pPaletteId);
			System.Diagnostics.Debug.Assert(item != null);
			String name = item.Name;
			uint i = 0;
			if (name != "SimplePalette")
				for (i = 0; i < maxMenu; i++)
					m_nMenuIds[i] = 0;
				throw new NotImplementedException();
				m_nMenuIds[i] =  Convert.ToUInt32(idCmdFirst) + i;
			Util.AppendMenu(new IntPtr(hMenu), MF_STRING, m_nMenuIds[0], "Menu&1");
			Util.AppendMenu(new IntPtr(hMenu), MF_STRING, m_nMenuIds[1], "Menu&2");
			Util.AppendMenu(new IntPtr(hMenu), MF_STRING, m_nMenuIds[2], "Menu&3");
			return 0;
		public override UInt32 InvokeMenuCommand(UInt32 idCmd, ref Guid pPaletteId, UInt32 hWnd)
			if (idCmd == m_nMenuIds[0])
				MessageBox.Show("Menu1 chosen");
			else if (idCmd == m_nMenuIds[1])
				MessageBox.Show("Menu2 chosen");
			else if (idCmd == m_nMenuIds[2])
				MessageBox.Show("Menu3 chosen");
			return 0;
		/// <summary>
		/// CustomToolBase override
		/// </summary>
		/// <param name="?"></param>
		public override bool ExecuteCallback()
			Point3d ptStart = new Point3d(m_startX, m_startY, m_startZ);
			Point3d ptEnd = new Point3d(m_endX, m_endY, m_endZ);
			Database db = HostApplicationServices.WorkingDatabase;
			TransactionManager tm = db.TransactionManager;
			using (Transaction t = tm.StartTransaction())
				BlockTable bt = (BlockTable) t.GetObject(db.BlockTableId,OpenMode.ForRead);
				BlockTableRecord btr=(BlockTableRecord)t.GetObject(bt[BlockTableRecord.ModelSpace],OpenMode.ForWrite);
				using (Line	l= new Line(ptStart,ptEnd))
					btr.AppendEntity(l);
					tm.AddNewlyCreatedDBObject(l,true);
				t.Commit();
			return true;
		public override bool DropCallback (Autodesk.AutoCAD.DatabaseServices.Entity entity)
			return false;
		String m_cmdName;
		String m_flyout;
		double m_startX;
		double m_startY;
		double m_startZ;
		double m_endX;
		double m_endY;
		double m_endZ;
	class Util
		[DllImport("user32.dll")]
		public static extern bool AppendMenu(IntPtr hMenu, UInt32 wFlags, UInt32
			wIDNewItem, string lpNewItem);
	public sealed class Command
		/// <summary>
		/// Define an AutoCAD command called 'CreateSimple'
		/// This command will create the Simple tool and add it to ToolPalette catalogs
		/// </summary>
		[CommandMethod("CreateSimple")]
		public void DoIt()
			// Get the tool GUID;
			Type t = typeof(SimpleTool);
			GuidAttribute guidAttr = (GuidAttribute)t.GetCustomAttributes(typeof(GuidAttribute), false)[0];
			Guid guid = new Guid(guidAttr.Value);
			// don't redefine the stock tool if it's already in the catalog
			ToolPaletteManager mgr = ToolPaletteManager.Manager;
			if (mgr.StockToolCatalogs.Find(guid) != null)
				return;
			SimpleTool tool = new SimpleTool();
			tool.New();
			Catalog catalog = tool.CreateStockTool("SimpleCatalog");
			Palette palette = tool.CreatePalette(catalog, "SimplePalette");
			Package package = tool.CreateShapeCatalog("*AutoCADShapes");
			tool.CreateFlyoutTool(palette, package, null);
			ImageInfo imageInfo = new ImageInfo();
			imageInfo.ResourceFile = "TOOL1.bmp";
			imageInfo.Size=new System.Drawing.Size(65,65);
			tool.CreateCommandTool(palette, "Line", imageInfo, tool.CmdName);
			tool.CreateTool(palette, "Custom Line",imageInfo);
			mgr.LoadCatalogs();
ShricharanaB
I tried to modify the "ExecuteCallback()" method to import and insert the block at point(0,0,0) (just to test) by adding two strings (block name and block path) in the SimpleTool class but clearly my understanding is wrong because it gives runtime error "Specified cast is not valid" at "tool.CreateFlyoutTool(palette, package, null);" line 240.
Also, in the simpletoolpalette project, without any modifications, It runs and creates the tool palette with three tools. One with flyout, one for line command and one for custom line. The first two tools work. But when I click on the custom line tool, I get the error "unable to execute tool, class not registered".
Has anyone any idea about this?
Thanks in advance for any help.
acadadmin3KNUF
Have you succeeded in this task?  I desperately need the same thing!  "...So, I want to create a command that iterates through all these folders, drawings and block, creates an index for each block, then creates a new tool palettes for each block without me having to drag and drop each and every block into the tool palette...."
