How can I know the Caps Lock is on/off by lisp
Message 1 of 23
Hello. How can I know the Caps Lock is on/off by lisp?
Replies (22)
Message 2 of 23
hak_vz
You can not do this directly, but you can use  DOSLIB
(dos_capslock 1) = on
(dos_capslock) = off
Miljenko Hatlak
Message 3 of 23
Sea-Haven
Why ? If a problem of case there are change case code out there or in a IF use (case str) forces caps.
Message 4 of 23
thank you.
Is that set up?  If I jist want know the status on/off.How can I do?
Message 5 of 23
I want to control a lisp to work on or not. For example. If Caps Lock is on,the plug-in unit dosen't work.
Message 6 of 23
Sea-Haven
If its open code then the CASE function should fix the problem.
Message 7 of 23
thank you.examples
Message 8 of 23
hak_vz
@Anonymous
If you know some autolisp it easy to do. I have pointed out name of the function you should use.
Download DOSLIB, and create something. I don't use it lately and have no time to write examples, but you can certainly find a lot of examples by simply googling for "autolisp doslib".
Miljenko Hatlak
Message 9 of 23
thanks.I'll learn it .It's useful & helpful.
Message 10 of 23
Kent1Cooper
Here's a routine I ran across some time ago, that I have used to force Caps-lock on when I start up AutoCAD [via acaddoc.lsp], which you may be able to modify to force it off.  It works through MS Word.
;; Turn Caps Lock on: [edited from Tim Spangler in "Caps Lock," theswamp.org 04/09/12]
(setq
  isMSW (vlax-get-object "Word.Application"); nil if Word not running already
  MSW (vlax-get-or-create-object "Word.Application"); whether or not already
); setq
(if (= (vlax-get MSW 'CapsLock) 0); Caps Lock is off
  (vlax-invoke-method
    (vla-getInterfaceObject (vlax-get-acad-object) "WScript.Shell")
    'SendKeys "{CAPSLOCK}"
  ); -invoke
); if
(if (not isMSW) (vlax-invoke-method MSW 'quit)); Exit Word only if not otherwise in use
(vlax-release-object MSW)
Kent Cooper, AIA
Message 11 of 23
Thank you very mach.I have tried it and It's good.Muth computers have MS Word.
Message 12 of 23
Sea-Haven
i FOUND THIS, (acet-sys-keystate 20) it returns 0 or 1 for on / off. Acet is part of express tools and works in Bricscad.
20 is capslock
Message 13 of 23
diagodose2009
You transform your-programe to programe_jc10aro.lsp. All calls from original source will be redirected
to one caller named (jc_aro10 "name-of-function" )..
The main tricks, you can insert the
Command: (acet-sys-keystate 20)
(acet-sys-keystate 20) as function. When the capslock=1 entire program, has be stopped.
Please you insert the "(acet-sys-keystate 20)" inside (defun jc_aro10...........
Message 14 of 23
TomBeauford
To make sure Caps Lock is off
(if(=(acet-sys-keystate 20)1)(vlax-invoke-method (vla-getInterfaceObject (vlax-get-acad-object) "WScript.Shell") 'SendKeys "{CAPSLOCK}"))
To make sure Caps Lock is on
(if(=(acet-sys-keystate 20)0)(vlax-invoke-method (vla-getInterfaceObject (vlax-get-acad-object) "WScript.Shell") 'SendKeys "{CAPSLOCK}"))
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 15 of 23
TomBeauford
Just for fun
To make sure Num Lock is off
(if(=(acet-sys-keystate 144)1)(vlax-invoke-method (vla-getInterfaceObject (vlax-get-acad-object) "WScript.Shell") 'SendKeys "{NUMLOCK}"))
To make sure Num Lock is on
(if(=(acet-sys-keystate 144)0)(vlax-invoke-method (vla-getInterfaceObject (vlax-get-acad-object) "WScript.Shell") 'SendKeys "{NUMLOCK}"))
Keyboard Key Code Values
https://www.oreilly.com/library/view/javascript-dhtml/9780596514082/apb.html
2023
Message 16 of 23
john.uhden
@Anonymous
That's a noble idea, but capslock can be on or off and the user can hold down the shift key, so you cannot control the raw input.  I think that with using grread you can make the user feel as though the case is out of their control, but you can't use grread within a dialog box or other standard AutoCAD input dialogs.
John F. Uhden
Message 17 of 23
Thank you very much for your reply. My friend asked me to make a reactor plug-in for him, but sometimes he don't use it. So he want to use a switch to control whether the reactor works, and specify to use the cap lock key to control it.Is there a better way?
Message 18 of 23
john.uhden
You've made me think that a command-reactor might be what you want. It
could be set up to take action on the start of only certain commands
thereby allowing the reaction to turn capslock on or off before the user
provides any input.
John F. Uhden
Message 19 of 23
JBerns
Has the acet-sys-keystate function changed its load behavior in AutoCAD 2025?
It seems that code that worked in AutoCAD 2022 is not working in AutoCAD 2025.
I added this code to restore its functionality:
;; load AutoCAD Express Tools
(if (null acet-sys-keystate)
  (if (findfile (setq ETU "acetutil.fas"))
    (progn
      (load ETU)
      (setq ETU nil)
    ) ;_progn
  ) ;_if
) ;_if
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 20 of 23
BlackBox_
(setq
); setq
  (vlax-invoke-method
  ); -invoke
); if
This topic & mentioning Tim brings me back... Thanks, Kent!
https://www.theswamp.org/index.php?topic=41461.msg465692#msg465692
Cheers
"How we think determines what we do, and what we do determines what we get."
Chris (BlackBox) Bradley
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
