How can i choose these numbers only ?? Picture attached
Message 1 of 8
this text has been written in same layer i want to choose these numbers only in one click sfsfdf.JPG
Picture attached
Replies (7)
Message 2 of 8
john.vellek
HI @Anonymous,
I am not aware of any feature or express tool that can do this action in a single click. I suggest that you look in the Autodesk App Store  or in the Customization forum to see if someone has such a routine.
John Vellek
Message 3 of 8
Patchy
Qselect, select the unwanted texts, move to another layer, then move them back later?
Message 4 of 8
Kent1Cooper
(ssget "_X" '((0 . "*TEXT") (1 . "6.5,6.55,7.5")))
That's looking at total text-string content, so it won't find any if they're Mtext objects with any internal formatting, or if those numerical values are part of longer Mtext strings with word wrapping, and not separate objects.  It could be made to find longer strings that contain  those bits within them, if you need that.
Kent Cooper, AIA
Message 5 of 8
ВeekeeCZ
Or another way around as Patchy suggested. Select all text and exclude those containing *-*
Message 6 of 8
john.vellek
HI @ВeekeeCZ,
Great ideas from both you and @Patchy.  I am just unsure as to what other text is present on the same layer as the image only shows a few objects.  I hope the exclude will work for the OP.
John Vellek
Message 7 of 8
roland.r71
That's asuming the numbers are limited & known.
How about letting the user select an entity, retrieve that entities layer, select all text on that layer,
test each if its a real or integer, add to new selection if so. (?)
then:
Use the selection inside lisp to do ... whatever
or preselect it, so the user can do ... whatever
Message 8 of 8
hmsilva
Try to use as Wildcard Match
Hope this helps,
Henrique
