How can I change a layers color using a script?
Message 1 of 9
I can freeze and thaw layers, but how can I assign a new color to a layer?
when I select color this
it asked for Truecolor or COlbook....
so I don't know where to go from here
Accepted solutions (3)
Replies (8)
Message 2 of 9
hmsilva
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: c
New color [Truecolor/COlorbook] : <<<from 1 to 255>>>
Hope this helps,
Henrique
Message 3 of 9
thank you
Message 4 of 9
hmsilva
@Anonymous wrote:
thank you
You're welcome, jthornton23MF3
Glad I could help
Henrique
Message 5 of 9
can you using scripts on specific viewports?  both indidvidually and batch
Message 6 of 9
hmsilva
Script, a *.scr file?
VPLAYER command?
If there is only one Viewpor in a specific Layout, yes.
Henrique
Message 7 of 9
I got the script to work by making the layer, which I want to change it color to the current color, see below....
-layer
SET
A-WALL-PATT-G
C
13
SET
0
QSAVE
;end of script
Do I have to make the layer current before changing its color?
If I have multiple xrefs all containing the the layer "A-WALL-PATT", how can I select all of them and change their color?
Message 8 of 9
hmsilva
Try
-layer
C
13
A-WALL-PATT-G,*|*A-WALL-PATT*
QSAVE
;end of script
Hope this helps,
Henrique
Message 9 of 9
Kent1Cooper
-layer
SET
A-WALL-PATT-G
C
13
SET
0
QSAVE
;end of script
No.  You can just give the Layer name inside the color option, and whatever the current Layer is will be irrelevant.  If the setting of Layer 0 current afterwards is only because that's what you expect to be the current Layer when you do this, and you want to leave it that way, you can then omit that resetting:
-layer
C
13
A-WALL-PATT-G
QSAVE
Kent Cooper, AIA
