Hideprecision = 1
Hideprecision = 1
maciej0202g
Hideprecision = 1
maciej0202g
Good evening, is it possible to turn on the Hideprecision = 1 command automatically? Sometimes I forget to turn it on before plotting. He works with Autocad 2015
komondormrex
Kent1Cooper
That System Variable became obsolete with Acad 2018.  But under versions that still have it, from the options in the link in Message 2, I would use the acaddoc.lsp approach [it runs in every drawing you open or create], in which I would put [assuming this one works like most System Variables]:
(setvar 'hideprecision 1)
Kent Cooper, AIA
Sea-Haven
Not sure about 2015 long time ago, using Appload, Start up Suite. You can add a custom lisp, that has all your variable settings, plus defun shortcuts etc. It will load on startup. That is what I have used for years, staying away from editing acaddoc.lsp.
