Help with WCMATCH
Help with WCMATCH
msarqui
Message 1 of 12
Help with WCMATCH
msarqui
Hi guys,
May I have some help please?
I am trying to compare two variables with WCMATCH but without success.
tagstr= "{\\C256;This is a test with wcmatch\\Pinside an attribute multiline ####}"
oldstr= "####"
So, I did this but it is not working:
(wcmatch tagstr oldstr)
It always returns nil. What am I doing wrong?
Marcelo
Replies (11)
Message 2 of 12
The # is used to search for a single numeric character (example 0-9).
To search for the # character in a string you have to put a reverse quote in front of the #.
Also you have to have an * at beginning and end of oldstr to account for any other characters.
(setq tagstr "{\\C256;This is a test with wcmatch\\Pinside an attribute multiline ####}")
(setq oldstr "*`#`#`#`#*")
Message 3 of 12
msarqui
Many thanks mracad!
Message 4 of 12
msarqui
Last question:
I could also have ##### or ######### or ############## (more than four #) and this will also return True. So, Is there a way to limit to only four #?
Message 5 of 12
ВeekeeCZ
@msarqui wrote:
Last question:
Erase the surrounding asterisks.
(wcmatch "####" "`#`#`#`#")
Message 6 of 12
msarqui
Hi BeekeeCZ
(setq oldstr "`#`#`#`#")
Returns nil (it must return T with four # and nil to any other quantity of #)
Message 7 of 12
ВeekeeCZ
if always is at least a single character around:
(wcmatch " #### " "*[~`#]`#`#`#`#[~`#]*")
or simply
(wcmatch  " ####}" "* `#`#`#`#}*")
if the characters space and } are always around.
Message 8 of 12
Kent1Cooper
@msarqui wrote:
Last question:
If such Multiline Attributes are always in that same format, with the #### at the end and preceded by a space and followed by only a right brace, you can use the asterisk for whatever comes before [only], and tie down the rest to specifically that:
(setq oldstr "* `#`#`#`#}")
But if that sequence might fall anywhere within the content, I'm not sure it can be restricted to recognize only when there are exactly 4 of them.
Kent Cooper, AIA
Message 9 of 12
Kent1Cooper
I tried that earlier and did something wrong with it, so I thought it didn't work, but when corrected, yes, it can be restricted to four of them, after all.  BUT you don't need the reverse-apostrophe ` escape character on wildcard characters when inside brackets [see Help]:
Command: (wcmatch "testing ####}" "*[~#]`#`#`#`#[~#]*")
T
whereas with more than four:
Command: (wcmatch "testing #####}" "*[~#]`#`#`#`#[~#]*")
nil
or fewer:
Command: (wcmatch "testing ###}" "*[~#]`#`#`#`#[~#]*")
nil
Kent Cooper, AIA
Message 10 of 12
marko_ribar
(defun _wcmatch ( str char n / sub pos )
  (if (<= n (strlen str))
    (progn
      (setq sub "")
      (repeat n
        (setq sub (strcat char sub))
      (if (setq pos (vl-string-search sub str))
        (if (not (vl-string-search char (substr str (+ 1 n pos))))
          t
Command: (_wcmatch "abcde#######sdf" "#" 7)
T
Command: (_wcmatch "abcde#######sdf" "#" 6)
nil
Command: (_wcmatch "abcde#######sdf" "#" 8)
nil
HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 11 of 12
msarqui
Hi Kent,
Thanks for the reply. I start to understand the complexity of this because yes, that sequence might fall anywhere within the content, and the will not be aways there. I will do more tests with your solutions for a while.
Marcelo
Message 12 of 12
msarqui
Wow Marko, this was impressive!
Many thanks!
Marcelo
