Help with tab order number
msarqui
Message 1 of 8
msarqui
Hi guys,
How can I get the tab order number of the current layout?
The following routine gives me a list with the tab order number associated with the layout name. (thanks to hmsilva)
(defun c:GetLayNumber ( / doc lst)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for layout (vla-get-layouts doc)
	(if (not (eq "MODEL" (strcase (vla-get-name layout))))
		(setq lst (cons (list (vla-get-taborder layout) (vla-get-name layout)) lst))
	);if
);vlax
(setq lst (vl-sort lst (function (lambda (a b) (< (car a) (car b))))))
(setq lstfinal lst) ;;;Do something here to extract the tab order number associated with the current tab )
Now, lets say I want to put in a variable, only the tab order number of the current layout (getvar "ctab").
Any help please?
Marcelo
Replies (7)
Message 2 of 8
hmsilva
Hi Marcelo,
one way...
(if (/= (getvar 'ctab) "Model")
   (foreach x lstfinal
      (if (= (cadr x) (getvar 'ctab))
         (setq CurrentTabOrder (car x))
Hope this helps,
Henrique
Message 3 of 8
msarqui
Many thanks Henrique. I can see the logic!
Message 4 of 8
hmsilva
You're welcome, Marcelo!
Depending on your goal, you can also consider in building the list as a dottet pair list, and just test an association...
        (setq lst (cons (cons (vla-get-name layout) (vla-get-taborder layout)) lst))
(setq lst (vl-sort lst (function (lambda (a b) (< (cdr a) (cdr b))))))
(if (setq CurrentTabOrder (assoc (getvar 'ctab) lst))
    (setq CurrentTabOrder (cdr CurrentTabOrder))
Hope this helps,
Henrique
Message 5 of 8
msarqui
Interesting, I will give a look.
Marcelo
Message 6 of 8
S_S_SS
Hello sir,
excuse me i want to get the number of current layout sheet in a text field can you help me please ?
Message 7 of 8
hmsilva
@S_S_SS wrote:
Hello sir,
Hello @S_S_SS
try this code from @Lee_Mac
Hope this helps,
Henrique
Message 8 of 8
S_S_SS
thanks for help sir ,
when i copy this text to another drawing it give me  Sheet#of-1 and it needed to make my order (lfsheet) and select it to activate it
can you help me about this ?
