Help with SSGET
Help with SSGET
msarqui
Help with SSGET
msarqui
Hi guys,
I am having a hard day with a ssget selection with a list of blocks.
My variable blklst has this value ("A$C53873E18" "p1115" "p915")
So I am trying:
(setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 blklst) (cons 410 (getvar "CTAB")))))
And Autocad give : ; error: bad SSGET list value
Thanks for your help.
Marcelo
hmsilva
Hi Marcelo,
if blklst are INSERT names...
(setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (vl-string-left-trim "," (apply 'strcat (mapcar '(lambda (x) (strcat "," x)) blklst)))) (cons 410 (getvar "CTAB")))))
Hope this helps,
Henrique
msarqui
Many thanks Henrque, you saved my day.
Marcelo
hmsilva
Marcelo
You're welcome, Marcelo!
Glad I could help
Henrique
