Help with selection set
Jonathan3891
Advisor Advisor
Jonathan3891
I'm having an issue with a selection set.
This is a work in progress but what it does is creates 3d grating out the grate hatch pattern.
The problem I'm having is after the lines are turned into polylines, I'm losing the selection set "SS2".
(defun c:ttt (/ OS PTZ SS SS2)
  (setq OS (getvar 'osmode))
  (setvar 'osmode 7)
  (command "id" pause)
  (setq PTZ (rtos (setq PTZ# (caddr (getvar 'lastpoint))) 4 4))
  (command "-hatch" "_P" "Grate" "32" "" "S" pause "" "")
  (setq SS (entlast))
  (command "_.CHANGE" SS "" "_P" "_E" PTZ "")
  (command "explode" SS)
  (setq SS2 (ssget "_P"))
  (command "_pedit" "m" SS2 "" "y" "w" "3/16" "")
  (command "_.CHANGE" SS2 "" "_P" "_T" "1" "") ;;;SS2 stops working
On a side note.
How come this works:
But this doesn't work:
( getpoint "\nTEST POINT : ")
Jonathan Norton
Blog | Linkedin
Moshe-A
@Jonathan3891 ,
i'll start from the end, the following works cause the ID command saves the coordinates to LASTPOINT sysvar and (getpoint) does not.
back to start:
when you explode Grant Hatch Pattern it releases a group of Horizontal and Vertical lines - Agree? you can not join them to one polyline? plus EXPLODE does not puts the exploded objects in previous selection set so you can not expect to get them with (setq ss2 (ssget "p"))  [though there is a way to do this with vla-objects activex] but as said they will not be joined.
to gather all objects after explode you can do something like this:
(setq ss2 (ssadd) ename (entlast))
(command "explode" "last")
(while (setq ename (entnext ename))
  (ssadd ename ss2)
moshe
Jonathan3891
Thank you @Moshe-A  for your input.
I'm not wanting to join them to one polyline, only make them all polylines.
The selection set is working all the way up to the PEDIT portion.
After the PEDIT the selection set (SS2) become nil.
I'm looking for a solution to  keep the selection set after they are converted to polylines so I can apply a thickness to them
(command "_.CHANGE" ss2 "" "_P" "_T" "1" "")
Jonathan Norton
Blog | Linkedin
jwhite
The entities in SS2 are destroyed during the pedit command. All new entities are created. You'll need to do what Moshe_A suggests to gather all of the new pline entities.
Kent1Cooper
@Jonathan3891 wrote:
I'm looking for a solution to  keep the selection set after they are converted to polylines ....
Unfortunately, a selection set is a type of collection of entity names  [in this case, of the Line entities].  Those entities in the collection no longer exist  after they've been joined into Polylines.
One thing you can do:  Before the PEDIT, save the last thing drawn to a variable:
(setq ent (entlast))
Then after the PEDIT, put all the things resulting from that [all entities newer than that saved one ] into a selection set:
(setq newSS (ssadd)); initially empty
(while (setq ent (entnext ent)) (ssadd ent newSS))
Then do further operations on newSS
Kent Cooper, AIA
john.uhden
Ya can;t trust (entlast) to return the absouletly last entity created in the drawing database.  (entlast) may return a complex polyline with following vertices, or a block reference with one or more attributes.
I'm using my wife's laptop without any AutoCAD, so from memory,,,
(defun lastent ( / e elast)
  (setq elast (entlast))
  (while (setq e (entnext elast))
    (setq elast e)
  elast
That'll getcha the absolute last graphical entity in the drawing (prior to whatever action you take to create new entities).
John F. Uhden
