Help with repetition LAMBDA & MAPCAR
msarqui
msarqui
Hi everyone.
Instead of each (vla-SetCustomByKey si "T1 EXIS."... would be possible to use LAMBDA or MAPCAR in this function?
(defun RefillDP ( eid1 esc1 ete1 emo1 eaz1 eha1 emd1 / doc db si)
(setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq db (vla-get-Database doc))
(setq si (vla-get-SummaryInfo db))
(vla-SetCustomByKey si "T1 EXIS." eid1)
(vla-SetCustomByKey si "T1 EXIS. Secteur" esc1)
(vla-SetCustomByKey si "T1 EXIS. Technologie" ete1)
(vla-SetCustomByKey si "T1 EXIS. Mod. antenne" emo1)
(vla-SetCustomByKey si "T1 EXIS. Azimut" eaz1)
(vla-SetCustomByKey si "T1 EXIS. Hauteur" eha1)
(vla-SetCustomByKey si "T1 EXIS. MDT" emd1)
hencoop
(setq val1-list
   (list "T1 EXIS."
         "T1 EXIS. Secteur"
         "T1 EXIS. Azimut"
         "T1 EXIS. Hauteur"
         "T1 EXIS. MDT"
(setq val2-list
   (list eid1
         esc1
         ete1
         emo1
         eaz1
         eha1
         emd1
(mapcar '(lambda (x y) (vla-SetCustomByKey si x y)) val1-list val2-list)
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
ВeekeeCZ
...erased by the user.
Edit: Not sure if I see your goal...
(defun apply-vla-setCutsomByKey (lst si no)
  (foreach e lst
    (vla-SetCustomByKey
      si
      (strcat (car e) (itoa no) (cadr e))
      (eval (read (strcat (last e) (itoa no)))))))
(apply-vla-setCutsomByKey
  '(("T" "EXIS." 		"eid")
    ("T" "EXIS. Secteur" 	"esc")
    ("T" "EXIS. Technologie" 	"ete")
    ("T" "EXIS. Mod. antenne" 	"emo")
    ("T" "EXIS. Azimut" 	"eaz")
    ("T" "EXIS. Hauteur" 	"eha")
    ("T" "EXIS. MDT" 		"emd")
  si
  1)
Kent1Cooper
Probably, but (foreach) may be simpler.  Any way you do it will probably require constructing some kind of list(s).
(foreach x (list (list "" eid1) (list " Secteur" esc1) (list " Technologie" ete1) (list " Mod. antenne" emo1) (list " Azimut" eaz1) (list " Hauteur" eha1) (list " MDT" emd1))
  (vla-SetCustomByKey si (strcat "T1 EXIS." (car x)) (cadr x))
Kent Cooper, AIA
msarqui
Thank you all guys,
hencoop gave what I was looking for.
