Help with member
Help with member
DC-MWA
Message 1 of 8
Help with member
DC-MWA
I have this part of my code which works well.
(if (and (= TOC "5A")
(member OCC '("R-4" "R-2.1"))
(progn
(setq HTNS "50")
(setq HTS13D "50")
(setq HTS13R "50")
(setq HTS "50")
);end pr
);end if
I need to do something like this in another part of code...
(if (member OCC '("R-4" "R-2.1")
(progn
(alert "test successful!")
);end pr
);end if
Please help. Am I forced to (if (and ??
Replies (7)
Message 2 of 8
dbhunia
Did not get it ....... both are working for me.......
If TOC =5A & OCC =R-4/R-2.1
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 8
ВeekeeCZ
The code is fine, no end needed. The MEMBER function works fine.
Though for such a situation would pro probably little faster to use the VL-POSITION function.
Also setq could be combined...
         (vl-position OCC '("R-4" "R-2.1"))
  (setq HTNS "50"
        HTS13D "50"
        HTS13R "50"
        HTS "50"))
(if (vl-position OCC '("R-4" "R-2.1"))
  (alert "test successful!"))
But you can omit if entirely, and use just and. The result is the same. Some users prefers to build entire program that way.
(and (= TOC "5A")
     (setq HTNS "50"
           HTS13D "50"
           HTS13R "50"
           HTS "50"))
Or your second example may include the Error warning. The overall result would be still the same: T if OCC found, nil if not.
(or (vl-position OCC '("R-4" "R-2.1"))
    (alert (strcat "Error: Wrong input. " OCC " isn't allowed.")))
... all are just a minor tips. But all you can see quite often used in codes.
Message 4 of 8
martti.halminen
If you are doing tens of thousands of MEMBER calls, using VL-POSITION would be faster. If you are calling it just a few times, the difference is in milliseconds, so using MEMBER communicates the programmer intent more clearly to the next reader.
- This is essentially an Autodesk implementation failure: VL-POSITION does more work than MEMBER, so it shouldn't be able to be faster.
Regarding OR: in general Lisp programming you can often find usage like
(setq var (or (find-current-value...)
                       (find-default-value ...)
                       (ask-user ...)))
This won't work in AutoLISP.
Common Lisp:
> (or nil 5 'A)
5
AutoLISP:
_$ (or nil 5 'A)
T
So, in AutoLISP you can only use OR if you are either not interested in the value returned, or T/NIL as the return value is sufficient.
- similar difference also in AND.
Message 5 of 8
doaiena
You can go around that limitation with something like this:
(setq var (vl-some 'eval (list nil 5 'A)))
Message 6 of 8
martti.halminen
That is one way to do it.
Another possibility: using COND without result value, so it returns the test value:
(setq var (cond ((find-current-value...))
                ((find-default-value ...))
                ((ask-user ...))))
- needs one layer of parentheses more than the other versions.
Message 7 of 8
DC-MWA
Thank you all for the input. I plan on testing the several different ways of handling this.
My schedule has forced me to put this task off to a later date.
I will let you all know what worked best for me.
THANK YOU SO MUCH FOR ASSISTING ME!!!!
Message 8 of 8
john.uhden
@ВeekeeCZ wrote:
" Or your second example may include the Error warning. The overall result would be still the same: T if OCC found, nil if not.
Be careful there in case OCC is nil.
John F. Uhden
