I've downloaded and used the attached lisp routine with great effect but I wondered if its possible to list the X,Y,Z values with a number in order, for example:
1,579094.359,137991.396,0.000
2,579093.014,137994.12,0.000
3,579091.669,137996.843,0.000
4,579098.024,137999.982,0.000
5,579099.369,137997.258,0.000
6,579100.714,137994.535,0.000
currently I would have to manually input the 1 2 3 4 5 6.
Thanks for any help and suggestions.
Morgan
(defun vert (/ filterlist vla-obj-list
lwlist 2dlist ptlist vlist1
vlist2 vlist3
(vl-load-com)
(setq filterlist (make-filter)
vla-obj-list (get-objects filterlist)
lwlist (nth 0 vla-obj-list)
2dlist (nth 1 vla-obj-list)
ptlist (nth 2 vla-obj-list)
vlist1 nil
vlist2 nil
vlist3 nil
) ;_ end-of setq
(if lwlist
(setq vlist1 (make-list lwlist 2))
) ;_ end of if
(if 2dlist
(setq vlist2 (make-list 2dlist 3))
) ;_ end of if
(if ptlist
(setq vlist3 (make-list ptlist 3))
) ;_ end of if
(write-text vlist1 vlist2 vlist3)
(princ)
) ;_ end of vert
(defun make-list (p-list n / i vlist obj coords ca j x y z xy)
(setq i (- 1)
vlist nil
) ;_ end of setq
(repeat (length p-list)
(setq obj (nth (setq i (1+ i)) p-list)
coords (vlax-get-property obj "coordinates")
ca (vlax-variant-value coords)
j (- 1)
) ;_ end-of setq
(repeat (/ (length (vlax-safearray->list ca)) n)
(setq x (vlax-safearray-get-element ca (setq j (1+ j))))
(setq y (vlax-safearray-get-element ca (setq j (1+ j))))
(if (= n 2)
(setq xy (list x y))
(progn
(setq z (vlax-safearray-get-element ca (setq j (1+ j))))
(setq xy (list x y z))
) ;_ end of progn
) ;_ end of if
(setq vlist (append vlist (list xy)))
) ;_ end-of repeat
) ;_ end-of repeat
) ;_ end-of make-list
(defun make-filter (/ filter)
(setq filter '((-4 . "<OR")
(0 . "LWPOLYLINE")
(0 . "POLYLINE")
(0 . "POINT")
(-4 . "OR>")
) ;_ end of setq
) ;_ end of make-filter
(defun get-objects (filter / ss k lwp-list
2dp-list pt-list no-ent obj pl
2d pt
(setq no-ent 1)
(while no-ent
(setq ss (ssget filter)
k (- 1)
lwp-list nil
2dp-list nil
pt-list nil
obj nil
pl "AcDbPolyline"
2d "AcDb2dPolyline"
pt "AcDbPoint"
) ;_ end-of setq
(if ss
(progn
(setq no-ent nil)
(repeat (sslength ss)
(setq ent (ssname ss (setq k (1+ k)))
obj (vlax-ename->vla-object ent)
) ;_ end-of setq
(cond
((= (vlax-get-property obj "ObjectName") pl)
(setq lwp-list (append lwp-list (list obj)))
((= (vlax-get-property obj "ObjectName") 2d)
(setq 2dp-list (append 2dp-list (list obj)))
((= (vlax-get-property obj "ObjectName") pt)
(setq pt-list (append pt-list (list obj)))
) ;_ end-of cond
) ;_ end-of repeat
) ;_ end-of progn
(prompt "\nNo polylines or points selected, try again.")
) ;_ end-of if
) ;_ end-of while
(list lwp-list 2dp-list pt-list)
) ;_ end-of get-objects
(defun write-text (vl1 vl2 vl3)
(setq fn (getfiled "Text File" "" "txt" 1))
(setq f (close (open fn "w")))
(setq msg "Points from LW-Polylines")
(do-points fn vl1 msg 2)
(setq msg "Points from 2d-Polylines")
(do-points fn vl2 msg 3)
(setq msg "Points from Point entities")
(do-points fn vl3 msg 3)
(princ)
) ;_ end of write-text
(defun do-points (fn vl msg n)
(setq f (open fn "a"))
(write-line msg f)
(write-line " x, y, z" f)
(write-line "" f)
(foreach point vl
(setq x (nth 0 point)
y (nth 1 point)
) ;_ end of setq
(if (= n 2)
(setq str (strcat (rtos x) "," (rtos y)))
(progn
(setq z (nth 2 point))
(setq str (strcat (rtos x) "," (rtos y) "," (rtos z)))
) ;_ end of progn
) ;_ end of if
(write-line str f)
) ;_ end of foreach
(setq f (close f))
(princ)
) ;_ end of defun
(defun c:pts ()
(vert)
(princ)
) ;_ end-of defun
(prompt "PLIST.LSP by Tony Hotchkiss - enter PTS to start ")
