Batch and Script scheduler help needed
Good morning,
I have a batch and script which work together to do some tasks without my having to attend to them.
The Batch file starts AutoCAD, then runs a script which contains a set of custom commands to do extracts and plot dwf files. Examples below...
When I initiate the batch file manually it all runs perfectly to the very end; all dwfs are plotted fully and extracts completed correctly. That is, if people aren't working in their files; can't replace a dwf if it's open by someone.
If I set up Windows Task Scheduler to run the batch/script in the middle of the night, each task is only partially carried out, but doesn't complete. I get partial dwfs and partially completed extractions.
I would rather run this at 2:00 a.m. because at that time people are not working in their files and the dwfs can be overwritten.
The batch file looks like this:
START "" "C:\Program Files\Autodesk\AutoCAD 2018\acad.exe" /b "C:\Scripts\EXTRACTS.scr"
The Script is simply a list of custom commands:
BZEXTRACT
NCEXTRACT
RFS2DWF
D1XDWF
QUIT
Y
My machine is running Windows 10
The help I need is getting this to run in the middle of the night and run properly and completely. Are there any tricks to getting Windows Task Scheduler to function properly? Has anyone else seen commands only partially complete when using Task Scheduler? If so, how did you get around it? Is there a way to force a command in a script to fully complete before going on to the next one? Is there a better way to go about this?
As always, I appreciate the experience and sharing I find on this forum. Thank you for any helpful responses.
Erik
