Help with editing a lisp
FORBESWILSON6174
Message 1 of 1
FORBESWILSON6174
I am new to the forum, so please bear with me.
While we have moved on to modelling, I still have clients who want to see 2D Layout drawings for approval before modelling.
I have a menu and number of lisp routines which I have modified and used for drawing steel sections in 2D. They work well, however they were written in the 1990's.
I have made some changes to them, however the problem is that with the progress of AotoCAD to the CUI format, if I load and run the lisps, the menu file populates the command dialogue box with the section list and dimensions which is not ideal.
The lisps and menu still work, but if I use a client's computer, they get a bit sensitive with the addition of the lists.
I have been using Allan Wise' slt.lsp for steel sections which I have modified to suit South African Sections, and which uses a dcl file and dim file to read the dimensions, and while it is a great lisp, my lisp routines give more options in term of placement and double angles, starred angles etc.
While I can follow the process of both lisp systems, I don't have the ability to ether modify my lisps to run with dci files, or modify his lisp (which would be ideal) to incorporate my menu and lisp options.
My question is if there is anyone on the forum who would be prepared to modify the lisps for me.
Replies (0)
